Old 03-06-2007, 01:22 PM   #2 (permalink)
Briman42487
Briman42487's Avatar
Member Number: 7204
Re: AVIC D3 with 6 speakers ?
chances are that both front speakers, dash and door are wired in parallel to get 4 ohms, with only two speaker leads coming from the deck. in that case, check the ohms with a multimeter to make sure it is a 4 ohm load, then you will be fine with all six running. if it is a lower impedance, then the deck will most likely shut itself off when you get a little happy with the volume, if it doesnt shut off sooner than that.
Briman42487 is offline   Reply With Quote
