Old 03-16-2007, 06:11 PM   #216 (permalink)
SwissArmySuv
SwissArmySuv's Avatar
Member Number: 1693
Re: "Factory style" recessed fog lights in stock bumper (development stage pics)
Well Boys and Girls,
We are finally there, the final install has started!
I will post pics as I progress tonight (this is "semi-live" as I do it.)
Note: Holes were all drilled and harness was installed before I started.
#1 > install trim flanges (7:11PM EST)
#2 > lamps mounted to brackets and 1st aiming (7:35PM EST)
#3> rubber lamp "caps" installed (7:49PM EST)
Note: had to adjust terminals (slightly loose)
#4 > removed debries deflectors (8:04PM EST)
#5 > passenger side aimed and installed (8:45PM EST)
Note: Found I need to make a small adjustment on the install manual
#6 > drivers side aimed and installed (9:32PM EST)
Note: Took a little break during this one
#7 > just got back from a test drive, wow what a difference! (10:29PM EST)
Note: Not sure if the pictures do justice, they really increase the side lighting as claimed (exactly what I wanted).
headlights and fogs
fogs only
headlights only
headlights and fogs
headlights only
headlights and fogs
headlights only
headlights and fogs
will take some more final pics in the daylight tomorrow
Home of the Overhead Map Light/Mini-Console Kit
map light kit: http://www.fjcruiserforums.com/forum...tml#post929130
SwissArmySuv is offline   Reply With Quote
