Old 03-18-2007, 08:20 PM   #1
Terahex
Terahex's Avatar
Member Number: 1680
Location: HELL ...................... if I don't change my ways :)
StepByStep Install: Expedition One Sliders
There might already be another step by step installation thread, but I thought I would share my experiences.
My first step was to remove the exiting running boards. This turned out to be a little more difficult since they have scene some heavy trail abuse. I highly recommend people replace your running boards if you plan to go off road. The follow pictures shows that running boards just don't stand up to much
The running board mounts had to be hammered straight, in order for me to get a ratchet on the bolts.
Now to start the Slider Installation. I would highly recommend giving the underbelly a good pressure washing before starting. Having dirt and sand fall in your eyes is not fun . I would also run a bolt through all the mounting holes to clean out the threads. It is much easier to do now, than when you are trying to thread the bolt by hand while propping up a 20lb slider.
The first step in mounting the sliders was to remove the brake line mount
I found it easiest to hang the sliders by the front top mount. I placed just a bolt in the bottom hole. I slid the top slider mount on that bolt.
Now comes the hard part. You have to lift the bottom half of the slider, while threading a bolt into the bottom hole. I didn't use a wash since it made it more difficult to hold and line up bolts. Then do the same for the front mount. The sliders should now relatively line up with bolt holes. I did the bottom bolts and washers first. Be sure top holes line up before you tighten down the bottom bolts. Then I installed the top bolts.
The final step was to remove the initial mounting bolts and reinstall with the washers.
These look so much better then the running boards, and they are trail ready.
A BIG THANK YOU to James an Expedition One Sliders. He designed a great slider.
2007 Toyota FJ Cruiser MT6 VooDoo Blue (FE, CQ, GY, RB, UR, CF, C7, V5)
Mods: Kenwood DNX7100 | Expedition One Sliders | OME Medium Lift | Original Bandi Mount | CB | 285 Nitto TerraGrappler | HiJack Roof Mounts | ScanGageII | Rear Door Storage Net | TireCover Mod | PIAA Headlights | Passenger Armrest | VooDoo Tent Trailer
WishList: Skid Plates | Wet Okole
Member: NorthWest FJ Cruiser Club
Terahex is offline   Reply With Quote
