Old 03-19-2007, 05:56 PM   #6 (permalink)
RoverGGM
RoverGGM's Avatar
Member Number: 471
Re: A/T seems to drag after letting up off the gas
It's the "grade logic" programmed into the shifting parameters. It helps with descents by holding a lower gear. It's activated by an application of the brakes usually.
This is what edmunds had to say about it in regards to it's behavior in the 2007 Tundra:
Particularly impressive is the downhill grade logic. On a long descent, we didn't need to touch the brakes, as the transmission downshifts and steadfastly holds the lower gear.
RoverGGM is offline   Reply With Quote
