Re: FJ Alignment Specs
This info. was great. Firestone used it to align my FJ after the 2" leveling spacer kit. Thanks for posting it.
FJ Cruiser 4X2
FRONTSpecificationNeg. TolerancePos. ToleranceLeft Camber-0.57°0.50°0.50°Right Camber-0.57°0.50°0.50°Cross CamberLeft Caster3.57°0.50°0.50°Right Caster3.57°0.50°0.50°Cross CasterTotal Toe0.08°0.17°0.17°Left SAI12.92°0.50°0.50°Right SAI12.92°0.50°0.50°
2007
FJ Cruiser 4X4
FRONTSpecificationNeg. TolerancePos. ToleranceLeft Camber0.15°0.50°0.50°Right Camber0.15°0.50°0.50°Cross CamberLeft Caster2.82°0.50°0.50°Right Caster2.82°0.50°0.50°Cross CasterTotal Toe0.08°0.17°0.17°Left SAI12.35°0.50°0.50°Right SAI12.35°0.50°0.50°
When you get the alignment done the caster will more than likelly not go back to within specs. What you want to do is get camber as close to center as possible and have the right front caster be .40-.50* greater than the left side this will insure that the vehicle tracks straight and will have no tire wear issues as long as tires are rotated properlly.[/quote]
 2007 Loaded Sun Fusion 4WD automatic.
285/70-17 BFG's,Front light bar/ KC Black Chrome 100W lights, rear cargo cover, rear door cargo net, K&N filter, daystar lights, 2" front leveling kit, Fiamm high pitch horn, Scangauge II, Semi-custom overhead console/lights, 15" sport antenna, LED dome lights, Wet Okole seat covers, aux. backup lights, Garmin Nuvi 200 w/ FJ on map, LED taillights.
