Re: Bandi Mount
Sharkbait previously said:
there's so many antennas u can choose from nowadays, check out walcott's website, seems they have every antenna made for cb's and amateur radios. they even have mounts for laptops. not a bad selection, i just got done checking it out myself. i recommend the k40 antennas, since theyre so flexible, might save u money and time. just incase the others break, not gonna mention which brand. i hope it'll help u on ur search for an antenna. have fun
The big problem with K-40 antennas on the trail is that they are too flexible and they have a tendency to whip around. This can be damaging to your rig and dangerous to people around you. This is why Firesticks on a spring mount tends to the standard off road.
NUFC
Rig
Black Diamond M/T,Custom XM Inno mount , Bandi antenna mount/ Yaesu FT-7800r, 4 Piece Budbuilt Skids(still need the gas tank skid), OME 886/895, All-Pro upper and lower links, Procomp 7089, Procomp Extreme M/T's, Project Overkill rails,
Gear
Home Brew
Project Overkill
Always trust the Gene Genie
