Old 04-10-2007, 07:31 AM   #3 (permalink)
FJ FunJunkie
FJ FunJunkie's Avatar
Member Number: 7470
Re: why does instructions on my K&N sheet says this kit is not for "LIFTED" vehicles...
accunlmtd previously said: View Post
By installing the lift, your FJ now runs at a much higher altitude than the stock machines. The higher altitude results in lower air pressure as the milibars indicate on the optional altimeter ( which also has to be recalibrated if you do a lift job.) The instructions for this are contained within the manual, in the Optional equipment addendum. (instructions for the heated seats are also in there as well.)
Since the air filter was designed to operate at a specific range of air pressure, the manufacture has no control of the upper atmosphere environment that you may be operating in due to the lift.
And this is all Bovine Scat which you probably realize by now.
Al in Colorado
Bovine Scat HAHAHAHAHAHAHAHAHa
Ligten up, it's the internet!
Quote from: BigDouggieDoug
You Should Help Chris Walk
Quote from Suecyde: Call it Stupidity...I call it Great. --> but unless you have done one of these things to or with your FJ...YOU WOULD NOT UNDERSTAND!!
FJ FunJunkie is online now   Reply With Quote
