Thread: gear for trails
Old 04-10-2007, 08:52 AM   #7 (permalink)
cannondale@juno.com
cannondale@juno.com's Avatar
Member Number: 3100
Re: gear for trails
sweet, that was exactly what i was looking for, I formally guided backpacking trips in NM and CO, so most of the gear lists look like common sense, we never really had to go offroad to get to any of the trailheads, and we obviously had all of our backpacking gear with us. I wanted to know what my fj needed or what was expected for me to have to run an organized trail run, ex. walkies or a cb, etc...
Thanks so much,
matt
k9crazy previously said: View Post
Here's some helpful info I haven't seen posted yet (although I didn't look very hard). This is the TLCA (Toyota Land Cruiser Association) checklist for vehicles to attend TLCA sanctioned events.
TLCA Vehicle Inspection Requirements
Vehicles registered for participation in a TLCA, or TLCA sanctioned, event are subject to a 'Vehicle Inspection'. And though TLCA makes no representation as to the impact of such an inspection upon 'safe' participation in an event, failure to pass such an inspection will disqualify the vehicle from participating in the event.
All determinations pertaining to the 'Vehicle Inspection' shall be at the sole judgement of the event committee, and/or its designates, responsible for such inspections. If a vehicle fails to pass an inspection, correction of any deficiencies may be attempted and the vehicle reinspected ... provided such correction and reinspection can be conducted without impact to event schedules.
minimum vehicle requirements
The following are minimum vehicle requirements which, if not met, disqualify a vehicle from participating in an event:
Vehicle Registration: Must be current Liability Insurance Coverage: Must be current, and meet applicable governmental requirements.
Service Brakes: Must be able to stall engine when idling in 2nd gear (1st gear if 3 speed)
Parking Brake: Must be able to stall engine when idling in 3rd gear (2nd gear if 3 speed)
Brake Lights: Must be functioning properly
Tires: All tires, including spare, must have at least 2/32" of tread. Spare tire must be fully inflated. Air down to a maximum of 15 psi prior to safety inspection
Roll Bar: Any open vehicle must have a roll bar firmly attached to the vehicle
Seat Belts: Required for driver and each passenger
Fire Extinguisher: Must show full charge on gauge and/or have seal intact
First Aid Kit: Recommended to be as complete as is reasonably possible
Antenna Length: Not longer than 54", unless both ends are firmly attached to the vehicle
evaluated items
The following are evaluated items which, depending on severity and/or quantity of deficiencies, may disqualify a vehicle from participating in an event:
Headlights
Running Lights
Turn Signals
Windshield: No dangerous cracks
Wipers
Horn
Exhaust System: Must be intact. No open exhaust, excessive noise or excessive smoke
Steering: Check play in wheel, condition of column and mounting hardware, knuckle arms
Hoses & Lines: Water, gas, brake lines (Please do not bring a vehicle with excessive leaks to an event. Such leaks can be damaging to the environment.)
Vehicle Jack: Hi-Lift type recommended
Tow Strap, Tow Rope and/or Chain
Winch
items to consider
The following are recommended items which TLCA encourages you to consider:
CB Radio
Tools
Fan Belt, Radiator Water, Battery Cables
Tire Gauge, Tire Pump, Tire Patch Kit
Rags, Hand Cleaner, Litter Bags
Axe, Shovel
Flashlight, Spare Batteries, Spare Vehicle Key
cannondale@juno.com is offline   Reply With Quote
