Old 04-10-2007, 10:03 AM   #10 (permalink)
robsatx
Member Number: 4988
Re: How to install a great sound system in your FJ
RipsFJ previously said: View Post
I will try to be humble when I say this ... all you have to do is follow how I set up my system, and you will end up with a great sounding system in your FJ.
Here are my 8 keys to having a great sounding stereo in your FJ.
1. Less is best! Don’t fill your FJ up with drivers just because you have the room! In other words, don’t waste your money on drivers located behind your ears, unless they are subs!
2. Use a HU that has at least a 4V pre-out section.
3. Use a 3-way component for the front that you can bi-amp.
4. Make sure your 3-way component has a very large sub/mid bass driver, preferably a 9 inch driver for the doors. Also, make sure the components include a soft dome mid. There is nothing warmer or smoother sounding then a soft dome mid.
5. Mount the mids and tweets in the dash/pillar area. This will result in great imaging, and fantastic up/forward sound stage.
6. Use 2 10 inch subs and point them towards the back of the vehicle.
7. You can run this whole system with a 4 channel amp, and a single D-class mono amp for the subs. Don’t under power anything …. Overpower if you must.
8. Tune your system, tune it again, and then tune it some more.
These steps are for those that want a nice sounding system. It’s not the loudest, it doesn’t have the booming bass, but it’s just clean and accurate …. The way music is supposed to sound.
Have you noticed that my key steps reflect how I set up my system?
How much did you spend on your system? This would be in the above "great" sound system. My last system ended in a similar fashion as what you are describing, a good head unit capable of peforming active xovers is the way to go. Along with MidBass drivers.
I have learned the following rule.
85% will schlep speakers everywhere and add an amp
12% will perform a good - great install.
2% will put in a really good system
1% will just go insane!
This post is intended to put a great sounding system without breaking the bank. Will sound 1K better than stock and 10 times better than just slapping speakers everywhere.
robsatx is offline   Reply With Quote
