robsatx previously said:
How to install a great sound system in your FJ
Your ears can localize most music in the range above 90Hz. Since most subs should operate below 80hz (in the 20Hz – 80Hz range), in a good system you should not be able to localize the Bass. In other words, you ears can not tell where the bass is coming from. On the other hand, music above 90Hz, is easily localized. You ears can tell where the music in this range is coming from. This is why the placement of your drivers (speakers) is extremely important.
Above 300Hz for localization.
