Thread: Rear Bumper
Old 04-20-2007, 05:26 PM   #24 (permalink)
DenverFJ
DenverFJ's Avatar
Member Number: 8159
Re: Rear Bumper
MoabRat previously said: View Post
Well, since the pipe is hot enough to deliver 3rd degree burns I merely wondered. I realize that the exhaust is routed through the rear facia on a lot of cars but I am not aware of the materials used to achieve this. It was just a thought.
Sorry if my comment came across as rude in any way ... it truely wasn't intended to be.
Yes, the pipes can get pretty hot, not as much when moving as sitting obviously. For the most part only a small percentage of the heat is transmitted to the adjoining surfaces, if the pipe is tight against the bumper more heat will be transferred than if there is a gap (heat doesn't bridge gaps well as it has to raise the ambient air temp first and also compete with air flow). The area immediately around the pipe might get a little warm, but with a surface area as large as a bumper I would expect the heat to dissipate rather quickly and not build up to a point where it would be a problem.
For my personal installation, I would probably want the hole in the bumper just big enough for the exhaust and use some sort of tip to finish it off nicely (not sticking out too far though), and that would also mean a little less heat transferred to the bumper.
Mark
DenverFJ is offline
