ironranger previously said:
The face plate is not used.
As for the black side trim pieces, I used some sharp wire cutters to clip off anything that was overlapping with the metal mounting brackets.
Man, I'm totally not picturing this.
When I say 'faceplate', on the scosche, I mean the thing that goes around the face of the D3... the rectangle with trim on the sides. And then there are 2 side bracket pieces. Which of those 3 chunks need clipping? Am I correct in assuming that you don't use the metal brackets from the stock radio, and use the plastic scosche brackets instead?
