Re: New Exhaust With PICS!!!!!
Are you intending on using your vehicle off-road? If so, reducing exhaust back-pressure may hurt more than it helps. Your low-end torque will be sacrificed to purchase the high end power. Does anyone know if you can install a butterfly valve in the exhaust to enhance back pressure at will and still run larger pipes? Just a thought. Several automotive makers have valves that adjust under WOT (motorcycles too) to enhance top-end power without sacrificing the advantage of low-end torque.
