Old 06-18-2007, 11:20 PM   #1
sbechtold
Member Number: 639
sbechtold's Project FJ Cruiser SAS
OK, it's been a while in the planning stages, but the IFS has hit the floor... My SAS started today at Demello Offroad. The front will be a 3-link setup with 14" Fox coil overs using a Diamond Axle housing. Running 4x4Labs steering arms and 1-ton TRE's, OTT pitman arm, Fox Air Bumps on all four corners and Currie Anti-Rock sway bar. The axle is 67" wide WMS-to-WMS and will be running an FJ80 high pinion elocker 3rd with 4.88 gears. I have a Diamond rear axle on order that I will install later this year at home. In the meantime I am reusing the the stock axle. The rear setup will be 62" Deaver springs with 14" Fox shocks. We might need to run 12" rear shocks as there isn't a lot of room under the FJC and I want to keep the height as low as possible.
Anyway, I spent the day tearing the IFS and rear OEM coil setup out of the FJC today. Jason then took the torch to the IFS cross members. Tomorrow I will grind everything then we'll start to mock up the suspension. I will continue to post updates as we make progress.
Ready for surgery:
Up on jack stands:
IFS parts are mostly gone:
Jason getting ready to cut:
He enjoyed this way to much:
Made quick work of the IFS:
One cross member down and one to go:
Everything off, now time to clean up and get closer:
Nice and clean, ready for grinding:
The obligatory shot of wheels w/o axles:
From the from - I think it's a little high in front:
Waiting for new legs:
Front Diamond Axle ready to go:
Rear OEM axle - need OEM brackets cut off:
The pile of IFS parts post removal:
The bling bling:
sbechtold is offline   Reply With Quote
