Re: 285\70\17 vs 285\75\16
Replied in blue...
poorbadger previously said:
If my math & my understanding is correct a 285\70\17 and a 285\75\16 are just about the same width and size in diameter with approx. an extra inch in sidewall on the 16" rim.
All things being equal are there any generalities that can be stated regarding the difference between the two with regard to ride quality and performance?
For example...
Will one have a smoother ride (absorb more shock) than the other? A tire with a taller sidewall will typically have a better ride than one with a shorter sidewall....if they are the same brand/type/circumfrence. Otherwise, if one has more sidewall plies it will be stiffer and flex less....hence a harsher ride (i.e. BFG AT "C" vs. "E".
Track better than the other? I think that is more dependant on tire width and tread design.
Be steadier in turns than the other? That would again depend on sidewall stiffness and tread design....not neccessarily 16" vs 17" tire.
Allow you to air down further than the other? 16" would have taller sidewalls, hence better for airing down, more flotation, etc...
Anything else? Assuming that the tires are the same circumfrence...16" allows better protection for the wheel rim bead against rocks, more tire choices....I think it looks cooler too IMO...
Thanks!
John
285\70\17
Width 285mm
Section Height 285 * .70 = 199.5mm
Section Height * 2 399mm
Wheel Diam 431.8mm
Tire Diam 830.8mm (32.71")
285\75\16
Width 285mm
Section Height 285 * .75 = 213.75mm
Section Height * 2 427.5mm
Wheel Diam 406.4mm
Tire Diam 833.9mm (32.83")
Mods: OME 883s / Body Mount "Chop" / 285-75-16 Dick Cepek Fun Country II / 16 X 8 Ultra 50 wheels / ARB Sliders / AFE CAI / Borla Cat Back Dual Exhaust / Pioneer DEH 6900 / Rockford Fosgate Components / Alpine Type R Sub / 35% Tint to match OEM / Forum Decal!  / Toyota Hood Protector & aluminum door sill plates
