Can I hang a T-Case off a 4X2 transmission? - Toyota FJ Cruiser Forum
» Auto Insurance
» Featured Product
Go Back   Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > 4x2 Discussion
4x2 Discussion This area is for discussion about the 4x2 equipped FJ Cruisers
Old 10-06-2009, 05:18 PM   #1 (permalink)
Member Number: 4711
Does anyone know? I hope to buy a 4x2 cruiser manual trans, then add a straight axle and an Atlas T-Case.
Any info is appreciated.
RaiderHater is offline
Old 10-06-2009, 06:13 PM   #2 (permalink)
Mtbcoach's Avatar
Member Number: 2433
Re: Can I hang a T-Case off a 4X2 transmission?
Anything is possible if you have the right skills, tools, time and $$$$.
If I understand your premise correctly, you are planning on buying a 4X2, converting it into a 4X4 with a solid front axle by adding an Atlas transfer case and running front drive shaft into the solid front axle.
Really not much different than someone who does the same but removes the front IFS diff. Check out the few solid axle conversions by sbechtold, MissFJ, M&M and you will see what's involved...
See me on ih8mud...
'07 GSJ15, well enhanced SOLD
'97 FZJ80 OME J
'77 FJ45
Olde North State Cruisers TLCA delegate
Train Hard, Rest Harder
TLCA 17784 - FCC KJ4KGF
Mtbcoach is offline
Old 10-06-2009, 06:16 PM   #3 (permalink)
VegasDlr's Avatar
Member Number: 14652
The manual transmission is only available in 4x4 so it has the correct tail housing to bolt to a transfer case. The problem is if you want an automatic. The automatic has a different tail housing depending on if you get it in 4x2 or 4x4.
VegasDlr is offline
Old 10-06-2009, 06:56 PM   #4 (permalink)
Cajun Moderator
Layonnn's Avatar
Member Number: 10006
x2 4x2 manual not happening, at least not from the factory.
1997 FZJ-80 Locked - Sold
-Layton
TLCA# 20623
Layonnn is offline
Old 10-06-2009, 06:59 PM   #5 (permalink)
Member Number: 4711
Thanks, I guess I will start with a 4x4 then.
Old 10-07-2009, 09:50 AM   #6 (permalink)
The Laughing Member
LandCruiserSteve's Avatar
Member Number: 8627
RaiderHater previously said: View Post
Good choice. You just saved yourself about $2k-3k (and one helluva lot of work) with your decision.
Steve Bolander
'07 FJ Cruiser
TLCA #6727 / UFWDA
LandCruiserSteve is offline
