All Pro Heavy Duty Tie Rods - Page 2 - Toyota FJ Cruiser Forum
» Auto Insurance
» Featured Product
Register Home Forum Active Topics Photo Gallery Chat Insurance Garage Blogs Search Today's Posts Mark Forums Read
Old 03-04-2010, 02:03 PM   #11 (permalink)
fjadventure's Avatar
Member Number: 23440
Re: All Pro Heavy Duty Tie Rods
No didn't break anything they were just there so I purchased them
I have an issue with buying things I see or at least that's what my fiancé tells me
fjadventure is offline
Old 03-04-2010, 02:42 PM   #12 (permalink)
E-ROCKER's Avatar
Member Number: 22255
SKINUM......Previously said:
I figured that but ya never know. Do, you get much rain where your located? If u do then keep the ends sprayed with some silicone so rust doesnt form. Definitely a nice product i've been happy with mine so far.
I'm in SoCal so it doesn't rain too much here but that's a good tip to remember. Thanks.
CaliChaos.........Previoulsy said:
so now that the weaker tie rod end has been replaced.. where do you figure the next break will be?
I am hoping not to break anything. I have wheeled the crap out of my rig for 2 years solid (every weekend) so even the expensive aftermarket parts eventually wear out. My Total Chaos uniballs needed replacement, cv's were making loud noises even in 2 wheel drive so they were replaced. Put on a set of used tie rods to find they had play in them just like my worn ones did, so HD tie rods were a good answer for me. The steering rack seems strong enough to handle the HD tie rods, although I was told by my alignment guy that I should consider replacing the bushings on the steering rack (worn).
I would say the spindle is the weakest link, but add the weld on gussetts and you should be good. Something is always going to give somewhere with enough force.......but cheap insurance is better than none.
5AND5TORM.........Previously said:
Did you bend or break a tie rod?
How many people have actually bent or broken an FJ tie rod?
I have heard of quite a few people breaking them on the trail (Tacoma's too)..........these will not break. With 35" tires and 4.56 gears those oem's just don't look like they're up for the challenge.
MrBigAxe.........Previously said:
So that replaces the inner tie rod as well?
Yes, it's the entire tie rod assembly. Replaces the inner and outer joints along with the shaft in between.
AllPro HD Steering/(F)Winch Bumper/(R)Bumper/Rock Sliders/Spindle gussetts/Diff skid/High Clearance Exhaust/IFS & Tranny skids/Ultimate Rear Links,Walker Evans 2.5 Coilovers & 2.5 Rears,Icon rear springs,Total Chaos UCA's,4:56 Gears,(R) E-locker & (F) ARB,AFE CAI,Doug Thorley Headers,Body Mount chop,315/75/16 BFG KM2's,AR Mojave's,Trail Gear T-Case skid,PIAA 40's,Bandi mount & Uniden PC68XL,Yaesu 2800M,Rock Lights,Blacked out,High Lift Jack,Custom Box with Cargo drawers and sleeping attachment.
E-ROCKER is offline
Old 03-04-2010, 04:56 PM   #13 (permalink)
FullJAM's Avatar
Member Number: 10540
5AND5TORM previously said: View Post
It did'nt break but i curve one with a 90degres of angle!!!!
With my friend, we put it back straight almost and put it back on the truck!!!
I was far from home, and i drive with it at max 30MPH...We were very careful! It cost a lot at the dealer but some part pas on warranty! A big bill!
this month i will install those new tie rod end
FullJAM is offline
Old 03-04-2010, 05:01 PM   #14 (permalink)
Cajun Moderator
Layonnn's Avatar
Member Number: 10006
Guy broke one at Katemcy Rocks year ago.
Layonnn is online now
Old 03-04-2010, 05:09 PM   #15 (permalink)
fj4M&E's Avatar
Member Number: 3510
that is cool. I just had the left inner tie rod replaced. If these replace the inner I'll look at these next.
thanks
Mike
Black fj loaded
arb bumper
IPF aux light
warn xp 9.5
viking synthetic winch line
PIAA 525 lights
king shocks
Budbuilt skids
Toytech Rr lower control arm
All pro Lower link skid
Total Chaos upper "A" arm
duel battery
Gobi roof rack
32" xmitter light
delta fog on the side
PIAA 2100 fog on the rear
fj4M&E is offline
Old 03-04-2010, 05:54 PM   #16 (permalink)
Yes I saw the gussets bought them and welded them on the same day I did the steering links
Old 03-04-2010, 06:05 PM   #17 (permalink)
frozengi's Avatar
Member Number: 26558
So whats the price of these?
frozengi is offline
Old 03-04-2010, 07:01 PM   #18 (permalink)
bc_indiana's Avatar
Member Number: 27847
fjadventure previously said: View Post
So with the gussets, can you use the anti-sway bar? That seems to be a very practical place to reinforce without damage to something else.
As for the links, yes they wouldn't break, but your forcing a break to the more expensive steering rack. Things are designed a certain way for a reason. The weak link should be cheap and easy to fix. If nothing has give, something major is likely to break. Thats why things are made to be replaced...to allow movement...to have give...to break first.
I am not convinced this is worth doing just yet.
bc_indiana is offline
Old 03-04-2010, 07:15 PM   #19 (permalink)
SKINUM's Avatar
Member Number: 18535
Send a message via MSN to SKINUM
Once, someone breaks the rack let me know.
It's not worth doing if you can't drop some f-bombs along the way!
THE BUILD OF SKINUM CLICK HERE TO VIEW
SKINUM is offline
Old 03-04-2010, 09:19 PM   #20 (permalink)
tisilverFJ's Avatar
Member Number: 1394
Angry Re: All Pro Heavy Duty Tie Rods
My steering rack is leaking. The thin rubber boots both ripped and the supplied zip-ties came off. I'm guessing dirt and water got in and ruined the seals. This is just from daily driving. The only off-road I have done was at last years FJ Summit with them on.
Toyota said they don't fix just replace. Steering rack $980 install $300. I found a place that said they can fix it for $335. I'm also going to try using metal straps to hold on shock boots in place of the supplied All-Pro boots. They are much thicker.
TLCA#16292
Toytec-coilovers,SS brake lines,front swaybar collars. http://www.toyteclifts.com/index.php...id=84&Itemid=2
Icon-piggy back rear shocks Metal Tech-LT rear coils.
All Phase Offroad diff skid,engine skid,Hi-Lift mount,axe/shovel mount,HD LCA frame mounts.
Spidertrax spacers.
All-Pro HD upper and lower control arms,HD steering arms,Bandi mount.
FabFours front bumper,Warn 9000XD winch,ARB rear bumper, 35's on KMC assault wheels.
tisilverFJ is offline
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
