Old 10-31-2006, 11:20 PM   #1 (permalink)
Admudistrator
Dragon's Avatar
Member Number: 2479
Offroad Lights and their usage.
Lights.
There are a few different types of lights that are used in offroad (and on road) situations. Some are ok to mount on top of your rig and some need to be down low.
Daylighters or Flood lights are usually the ones that people mount on top of their rigs. They completely light up the night and the terrain in order to see the "big picture" while driving offroad at night.
Here is Co-Jeff's killer ride that has this set up;
...and AtlantaCruising's set up;
Fog lights should never be up high if they are being used as fog lights. The reason being is; you want to illuminate the ground without getting any light reflection off of the moisture (fog or rain or snow) and back into your eyes. For this reason, you do not want the beam of light to cross your field of vision at all. Keep it as close to the ground as possible so there is no reflection back to you. They light up a wide path from left to right, but not very far down the road. You can't see far in fog anyway, but what they do is help you to see the surface in front of you and the sides of the road left and right.
Here is FJ Cruiser #8's rig, which shows how bumper manufacturers keep fog lights down low;
Driving lights are similar to stock high beams, but a bit more intense and a bit more isolated to "straight ahead" than the daylighter type of lights. They give you a good view of what is way down the trail, but if you had them on while rock climbing, they would appear as a spot of light right in front of you instead of lighting up the entire bluff you're climbing like a daylighter/flood light would. These are good for dirt roads or offroading where you have some decent stretch ahead of you that you need to view (good for seeing deer at night also).
Here is Air2Air's FJ which shows a great location for Driving Lights
Pencil lights are similar to driving lights but are even more isolated to a spot way down the road. This would be a perfect light for a Baja style race where you are going 90 MPH and need to see as far down the road as you can, but it does not illuminate left to right at all.
Here is The Donahoe Race Truck, running the Baja Peninsula races
A rally or Desert Endurance driver will have a good combination of a couple of different lights as they need to see the edge of the road as well as way down the road, and in all kinds of weather.
Here is Rod Millen's truck used to run the Baja 1000
Some like to just make sure they have it all covered.
Here is Cruiser Larry's very bright, very versatile setup;
And 1LegLance's set up (Photo by Miss R2FJ)
With any of these lights you do not want any part of the beam shining back into your own eyes even indirectly. This will cause a glare. Imagine if someone else is holding a flashlight for the both of you on a dark trail and part of the light is shining in your eyes. Can you see the trail? Yes, but you also squint due to the light in your own eyes. If you were to hold the light in your own hand pointing straight ahead, you don't get anything back in your own eyes and you see fine. Hold the light over your head or behind you but still shining forward and you see even better because there is no chance for the glare to enter your field of vision.
Different people like different lights for their own situations and lighting needs based on geography. My set up is done in a way to have my lights higher than any mud pit I slosh through or any water fording. I have fog lights on the outside and driving lights in the middle. This is really too high for fog lights, as they should be as close to the ground as possible, but I wanted them out of the way for approach angle and water crossings as well, so I sacrificed one thing for another.
I hope this helps. Many companies make good lights. PIAA, HELLA, IPF, WARN, KC and others. Choose the right light for your situation and don't let anyone dissuade you from setting them up how you want.
"Monzen no kozo narawanu kyo o yomu."
Experience is the best teacher
Taira
Click
Dragon is online now
Old 11-01-2006, 05:27 AM   #2 (permalink)
FJGypsy's Avatar
Member Number: 5376
Re: Lights and their usage.
Very informative and excellent post!!! Answered all the questions before I had a chance to ask them. Good job!!!
"You have the right to remain silent."
FJGypsy is offline
Old 11-01-2006, 05:44 AM   #3 (permalink)
Bang Bang's Avatar
Member Number: 3795
As usual from Dragon...great post with LOADS of info.
Mike
Where do you park your ride? Check this out...GarageFreaks.com
Acquired 07/03/06 2WD SUN FUSION
Member of the Hurricane Cruisers and damn proud of it!!
Thanks to Nate and Randy for their fine craftsmanship!!
Bang Bang is offline
Old 11-01-2006, 07:32 AM   #4 (permalink)
BMThiker's Avatar
Member Number: 3667
Very informative! Thanks for 'splaining so thoroughly. I need lights for my AP bumper and I want roof mounted lights too.
All-Pro bumper, USB links, IFS skid, Extreme LCA links, LCA skids & Bandi mount
Bud Built trans skid/crossmember/gas skid
Metal-Tech red sliders
OME 886/895 springs & shocks
Super Swamper 34" LTBs
Warn 9.5xp/Masterpull line
Demello rear bumper
My PhotoBucket
TLCA #16667 Ga Cruisers - Black Sheep Upstate Cruisers - Safety Officer
Things are more like they are now than they have ever been. ~ Gerald Ford
BMThiker is offline
Old 11-01-2006, 07:38 AM   #5 (permalink)
DirtyLittleSecret's Avatar
Member Number: 3950
AMEN! Ive tried to explain some of the basic theory of "lighting" one too many times. Finally something I can just throw out!
Here's some rep for ya!
FJC is gone, but not forgotten. Still got the FJ62!
DirtyLittleSecret is offline
Old 11-01-2006, 07:49 AM   #6 (permalink)
Hwtrader's Avatar
Member Number: 3787
Good timing Dragon, I am looking at some lighting right now and I needed a good lighting thread. Lets post up some brands / costs for those of you that have installed them.
Hwtrader is offline
Old 11-01-2006, 07:52 AM   #7 (permalink)
Admudistrator
Dragon's Avatar
Member Number: 2479
Hwtrader previously said: View Post
Mine are PIAA 580's for $230 here MVP Auto Parts :: Driving/Fog Lamps :: Piaa Lamp Kits :: Piaa 580 Series - Xtreme White Driving Lamps
Taira
Click
Old 11-01-2006, 08:04 AM   #8 (permalink)
Member Number: 3950
FJ Dragon previously said: View Post
These guys are awesome. Used to be Light Warehouse.
Old 11-01-2006, 08:05 AM   #9 (permalink)
Admudistrator
Dragon's Avatar
Member Number: 2479
DirtyLittleSecret previously said: View Post
Yes indeedy. I didn't buy mine there. One pair was a trade up courtesy of Marco at PIAA and one pair I bought locally (paid more but wanted them NOW )
Thanks for the kind words and rep points, guys.
Taira
Click
Old 11-01-2006, 03:29 PM   #10 (permalink)
Admudistrator
Dragon's Avatar
Member Number: 2479
Can anyone else post their lights and where they bought them from?
Taira
Click
