Questions on airing down tires. - Page 2 - Toyota FJ Cruiser Forum
» Auto Insurance
» Featured Product
Old 01-29-2013, 08:56 AM   #11 (permalink)
nkybrad's Avatar
Member Number: 50314
Re: Questions on airing down tires.
iwashmycar previously said: View Post
You can air down quite a bit, especially with an E tire. I usually go 15 and you cant hardly even tell by looks.
X2. Exactly the pressure i usually run at.
BRAD
MR. NAUGHTY AVATAR
2007 SUN FUSION
WWW.FORGEOVERLAND.COM
IN PROGRESS:
|FOX|ARB|CAMBURG|IRONMAN4x4|RICOCHET|WARN|ALL-PRO|
|BAJA RACK|GOODYEAR|METHOD|AMSOIL|TRDPARTS4U|BUSHWACKER|RIGID|
-TLCA #21735-
3. Keep your avatars free of nudity, pornagraphic, or racial images. The Off-Off Topic sections have been created so that people who want to see those items can, and people who DO NOT want to see them can avoid them. By using an inappropriate avatar/signature, you deny them the ability to avoid it. If an image offends you but does not violate this rule, please use the ignore user feature so that you do not have to view the users avatar.
nkybrad is offline
Old 01-29-2013, 12:25 PM   #12 (permalink)
No-Jeep-Jarrod's Avatar
Member Number: 30400
I know you asked about airing down. I have 265/75R16 BFG's and usually go down to 18 PSI. I know others go lower. You have to decide for your self how much ground clearance you want to loose. If I don't air down I really notice how bumpy the trails are. I've had my FJ since 2010 and mounted a compressor under the hood on the right finder, as seen in photo. Sweet talk some vendors and see who can get you a good deal. Mounting a compressor is a lot of work. FYI I built the aluminum tray myself for the compressor and the winch control box. As seen in the photo this is a tankless set up. With a wife,dog and seven year old, the rear cargo area is full enough.
No-Jeep-Jarrod is offline
Old 01-29-2013, 02:25 PM   #13 (permalink)
Member Number: 44298
Hmm, well I have found over the years that you DO NOT air down for snow. Sand yes, snow no. The tread won't clear very well (snow will get trapped in it if aired down).
I guess it depends on the tyres?
We also air down for muskeg (floating kind especially) in an effort to not break through.
Bruiser is a 2007 Black Cherry automatic "base" model
David Beale is offline
Old 01-29-2013, 02:44 PM   #14 (permalink)
tsy87's Avatar
Member Number: 40221
I got stuck in the snow, after airing down to 10 psi, I didnt get stuck anymore.
What it really boils down to is the type of snow you are dealing with.
2010 Army Green 4x4 6 Speed with some add-ons
tsy87 is offline
Old 01-29-2013, 02:57 PM   #15 (permalink)
FJess's Avatar
Member Number: 45014
There are really no rules here that work perfectly for every situation/tire size/tread type. Experiment with your setup and whatever terrain you find yourself on and see what works best.
Jessica
2011 Cavalry Blue with some added stuff.
ColoradoFJC.com
FJess is offline
Old 01-29-2013, 04:15 PM   #16 (permalink)
fj4M&E's Avatar
Member Number: 3510
Location: Co most of the time but live in the UK for now
found an okay video that covers airing down.
They seem to be more in the sand but it applies to wheeling in the snow as well. They hit on much more comfortable ride, better traction, tire conforms to the terrain rather than bouncing over everything.
If your running a DOT wheel I would be Leary airing down past 15 psi. I typically run between 20 and 25 depending on what I am doing
Once you are aired down you will not be able to travel at highway speeds it is unsafe and hard on the tires
also you will need a way to air up but it looks like you were working on that
should help
Mike
Black fj loaded
arb bumper
IPF aux light
warn xp 9.5
viking synthetic winch line
PIAA 525 lights
king shocks
Budbuilt skids
Toytech Rr lower control arm
All pro Lower link skid
Total Chaos upper "A" arm
duel battery
Gobi roof rack
32" xmitter light
delta fog on the side
PIAA 2100 fog on the rear
fj4M&E is offline
Old 01-29-2013, 05:44 PM   #17 (permalink)
FJX2000's Avatar
Member Number: 52569
Location: Cortez, Colorado (2 Hours away from both the FJ Summit and Moab)
Yeah for me, I air down to 25 from 36 usually to go wheeling, and that's what I've always done and it's what I'm comfortable with.
However, I know for Cruise Moab, they require you to be aired down to a maximum of 15 when they do your vehicle evaluation.
This scares me.
So what do you guys think about my setup being aired down that much?
FJX2000 - Hayden
2007 FJ Cruiser TRD Special Edition AT
See Ya At FJ Summit No.7 & Cruise Moab 2013!!!
Mods: 305/70R16 Fierce Attitudes, ReadyLIFT 3" Lift, Spidertrax, TRD Wheels, KC HiLiGhTs Slimlights, Rocktek Armor, Bushwackers, Blacked Out, LEDs all around, DDM Tuning 8000K HIDs, Light Racing UCAs, and so much more!!!
Go to my GARAGE or click here to see the STORM DAMAGE TRD build thread!
Or check out this thread to see all my FJ's Off-Road Adventures!!!
FJX2000 is offline
Old 01-29-2013, 05:46 PM   #18 (permalink)
iwashmycar's Avatar
Member Number: 46663
Send a message via AIM to iwashmycar
Are they E rated? 15 is still very sufficient. I wouldn't worry.
Tire beads are pretty stout
-Adam '07 Black Diamond 4WD AT UR
Bilstein 5100s | UltraGauge | Husky Liners | Yokohama Geolandar AT-S (E) - Offroad wheels | Powerstop brakes
OE Rock Rails | Ricochet Armor | Rocktek Link Armor | Midlands 75-822 - 2' Firestik - Boztec mount
Ellis Precision Shift knobs - e-brake | Discovery Overhead Console. w/ GPS
In NC or surrounding states? Check out North Carolina FJs for Trail Rides and Info.
iwashmycar is offline
Old 01-29-2013, 10:48 PM   #19 (permalink)
FJX2000's Avatar
Yes they are E rated, so that's good to know!! Thanks iwashmycar!
Also, on a side note, I recently saw a picture of your engine compartment and was admiring how clean it is!! So I was wondering, could you wash mine? I still have mud from when this happened in November of 2011!!!
FJX2000 - Hayden
FJX2000 is offline
Old 01-30-2013, 05:21 AM   #20 (permalink)
iwashmycar's Avatar
And that is why I dont touch mud if possible. Not worth it!
My engine bay had gotten covered and that was just driving through a 5' wide gulch of muddy water., albeit maybe a little too fast. Stuff was dripping out around the headlights and all that mess.
