I have never aired down tires for offroading before. What would be a safe pressure to air down a stock size tire for a 07 fj be? Also, how far can you go running at that pressure. Is airing down really help you get through the snow better. Like I said, I am new to this kind of four wheeling and would be using it in the spring, trying to get through the snow and into our fishing holes.
Generally not too much on a stock tire but if normal is 32 psi the maybe take it down to 22 psi. This will help ease the dirt-road washboard effect and give you some better traction. Keep it slow and air back up for higher speeds.
However, some stock tires probably should not be aired down.
Post what tires you have and someone else weigh in here.
TOTH 2012 | FJ Summit 2013
___________________________________
2012 FJ Cruiser | Silver Fresco Metal | AT
Sorry, should have said, stock tire size is, 265 70/ R17. Tire is, Goodyear Duratrac. Yes, I realize I will have to air up and I am looking into the Viair 450P as my compressor.
Nice, the Duratrac's are awesome and could go way down. I thought you where talking about the dealership Dunlop Road Tire.
No Worries
So, does airing down make a big difference in going on top of the snow or digging into the snow?
Airing down makes a huge difference in the snow. If you ever get stuck, try airing down a bit more (as low as 8-10) and see if you get moving again...it's very effective unless what has you stuck is being high-centered.
I would not wheel in the snow with out airing way down.
I've always been worried with my setup to air down too much. Because I have such wide tires (305/70R16s) on the very narrow TRD wheels (only 7.5 inches wide) there is quite a lot of budge, and i'm always afraid that if I air down too much, I'll break the bead and then be SOL
__________________ FJX2000 - Hayden 2007 FJ CruiserTRD Special Edition AT See Ya At FJ Summit No.7 & Cruise Moab 2013!!!
Mods: 305/70R16 Fierce Attitudes, ReadyLIFT 3" Lift, Spidertrax, TRD Wheels, KC HiLiGhTs Slimlights, Rocktek Armor, Bushwackers, Blacked Out, LEDs all around, DDM Tuning 8000K HIDs, Light Racing UCAs, and so much more!!!
Go to my GARAGE or click here to see the STORM DAMAGETRD build thread!
Or check out this thread to see all myFJ's Off-Road Adventures!!!
