I have not come across this anywhere yet, is there a way to disable the traction control for those times you want to go do a little rally driving on fire trails and need to hang the rear out a bit in 2hi
titanium silver '07 FJ package 1 with towing pak and toyota rock sliders, a-trac mod not needed
locked efi'd halfcab early bronco on 35"MTR's
04 disco
"can we get off these paved roads and find something a bit more fun and challenging, I could drive a Honda over that stuff
I only know how to disable VSC by remving the connector at the pump....But if you hurt yourself plase dont sue me for telling you......You can do a search also look for VSC
In one of the A-TRAC and rear locker hacks, there is a point where you splice into the wiring harness at the long connector on the side of the master cylinder and would then tap 12v to it. I just put a switch inline with the wire and did not do the "add 12v" to it. (waiting to see if Toyota will flash the ECU and/or not sure if I really need it yet). This will simply disable the VSC when you want to.
