Re: Finally CO2 Tank Installed...
FJ-Ollie previously said:
No different than a Powertank. And it's not flammable. The known hazards with CO2 is that it displaces oxygen causing an oxygen deficient atmosphere. This is also the same substance used in fire exringuishers. Another reason to install it standing up, other than you can use the bottle and not have to remove it, is that if the kneck of the bottle should break, the pressure would be driven downward and the bracket would keep it held in place. CO2 is relatively stable. Heat does cause it to expand. That's why the regulator has a built in pop off so it relieves the pressure before something catostrophically fails.
Regulator? built in pop off? relieving pressure before something catostrophically fails? CO2 relatively stable? Sorry dude, not for me. I hope you never experience a catostrophic failure or a bad vehicle accident with that bottle gas time bomb planted in your back seat. I'll pass.
07 FJ, SUN FUSION - 4x4 AT-Loaded, TOYTEC 3" Lift, BFG AT 285/70/17's, Romik Brush Guard, PIAA 540 DRL, xm.
06 BMW R1200 GS Adventure
