Old 01-05-2007, 06:02 PM   #1 (permalink)
FJoel's Avatar
Member Number: 4197
Optima Battery - Which one
I'm looking to buy an Optima battery as a second for my FJ for lights, winch, etc, but I don't know which one to get. I also need to get the Optima tie downs going as I have had so many requests for this.
What battery did you use and why?
Anyone have some measurements for me so I can make the tiedowns while I track down a Canadian dealer or what for one off ebay?
Thanks in advance!
Joel
FJoel is offline
Old 01-05-2007, 06:46 PM   #2 (permalink)
thugasaur's Avatar
Member Number: 691
Send a message via AIM to thugasaur Send a message via Yahoo to thugasaur
Re: Optima Battery - Which one
hey joel you ever thought of making the fit universal by making more clearance up the center for different kinds of batteries (over the service ports )?
just was thinking about it i may be way off
Chefj's Little known facts: Thugasaur tracked down, strangled, and gutted the Snuggle fabric softener bear because he once had a towel that was...well...not so soft.
UBFM member #00 enforcer
"Church" V2.0
2007 Voodoo 5AT 4x4
______________________
AFE cai , kenwood excelon 889 , xm2go, piaa extreme super whites , demello front skid plate and rock rails and aero flow lens covers (THANKS GUYS!) , all-pro front sway bar links
thugasaur is offline
Old 01-05-2007, 06:50 PM   #3 (permalink)
Good Times's Avatar
Member Number: 406
Yellow Top for it's deep cycle.
Check out Odyssey batteries too (heard they're good). (Odyssey Drycell Batteries)
Good Times is offline
Old 01-05-2007, 07:55 PM   #4 (permalink)
TCao's Avatar
Member Number: 940
I use an Optima D34 yellow top as the aux battery (the D31A won't fit on the right fender for my application). More info on Optimas here:
Technical Specs
TCao is offline
Old 01-05-2007, 08:20 PM   #5 (permalink)
FJoel's Avatar
Member Number: 4197
thugasaur previously said: View Post
I think the actual clamping width may be different too. The current clamps are a very good fit on the stock battery.
I think some of the optimas have the ports even futher apart and no fill caps...
Thanks for the info and link.
Keep the suggestions and batt types coming please.
FJoel is offline
Old 01-05-2007, 09:04 PM   #6 (permalink)
EDH-FJ's Avatar
Member Number: 4188
Do a search for Dual Battery and you will find pictures, installation instructions and so forth. Oh, and go yellow top...deep cycle is important for aux battery as it can take draining to almost nothing, while standard battery will fry.
2007 Sun Fusion 4x4 AT
CQ, Upgrade #2 A-Trac, Diff Lock
Roof Rack, Hitch
MODS:
Goodyear Wranger Silent Armor 275x70x17s
Dual Battery Setup
Locker Hack
All Pro Adjustable Suspension Front/Rear, Rear Springs
All Pro Rock Rails
All Pro Rear Links
All Pro Bandi Mount
Total Chaos UCAs
Budbuilt Skids
Cobra 75WXST CB
Scanguage II
Garmin 60 CSX GPS w/ external ant.
ARB Fridge
ARB Bumper w/ IPF fogs
Warn 9.5XP w/ Winchline Synthetic
PIAA 580 Driving Lighs
EDH-FJ is offline
Old 01-05-2007, 09:09 PM   #7 (permalink)
Skinpuppet's Avatar
Member Number: 442
Send a message via AIM to Skinpuppet
Blue top marine battery. Had one in a 4 runner once. It's good for
the vibrations when going off road and also make your sound system
a lot better.
Skinpuppet is offline
Old 01-05-2007, 09:10 PM   #8 (permalink)
FJ33's Avatar
Member Number: 7896
EDH-FJ previously said: View Post
Very true, and they come right back to life after a good charge. Deep cycles will last a log time then suddenly drop voltage, a normal battery will drop voltage right from the go.
Riding the handbasket through hell every day!
FJ33 is offline
Old 01-07-2007, 10:36 AM   #9 (permalink)
Gary A's Avatar
Member Number: 2881
Might want to look at Optima Group31A. It as 30 percent more starting /or winching capacity- freezing temperature. Batteries don't like cold any more than we do, and operate better. 900 Cold Cranking Amps @ 0 deg. F.
Gary A is offline
Old 01-07-2007, 01:13 PM   #10 (permalink)
White Rim's Avatar
Member Number: 3435
difficult to fit the 31a unless you do it sideways.
I used the yellowtop 34 as my 2nd battery, it really is the standard deep discharge battery for offroad use with extreme vibration and shock resistance and excellent deep discharge characteristics plus plenty of power to start your rig also if needed. Most folks go this route. See the posts by sbechtold
Dual Battery Installation Write-Up - Pics
White Rim is offline
