Old 02-26-2007, 07:52 PM   #1 (permalink)
Nevada_FJ's Avatar
Member Number: 3784
Need Bud Built Install Help
I just go two of the boxes still waiting for the other two and the gas tank skid. Do they come with any install instructions? I know it should be easy but if it can be messed up I will make it happen. I got a bag of hardware with the oil pan cover not sure where everything goes. Thanks for any and all help.
Nevada_FJ is offline
Old 02-26-2007, 08:18 PM   #2 (permalink)
sbechtold's Avatar
Member Number: 639
Re: Need Bud Built Install Help
Nevada_FJ previously said: View Post
Bud has written instructions. The install is very straight-forward and you won't screw it up. Either call Bud or email him to get the install document.
Member: TLCA / BRC / CA4WDC
sbechtold is offline
Old 02-26-2007, 08:25 PM   #3 (permalink)
TCao's Avatar
Member Number: 940
I assume you have the front and the center skid plate. First remove the two OEM skid plates. Next, install the nut plate onto the front skid (center rear hole) and then bolt the front skid plate to the four OEM mounting points with the new hex head bolts and flat washers provided in the bag. I used a hydraulic jack to help holding up the skid plates during the install. Insert the flat head screw (black oxide finish) through the countersunk hole in the center skid plate and bolt up on the front skid nut plate (keep this loose until the skid is aligned). Install the remaining four hex head bolts and flat washers; tighten the flat head screw. For the aft skid plate, you'll need to remove the four bolts holding the two diagonal crossmembers. Install the rubber bumper onto the aft skid and install the four flat head screws through the four countersunk holes in the aft skid plate. Install the two carriage bolts and nuts through the center skid and aft skid (the aft skid plate sits on top of the center skid plate). I don't have the fuel tank skid plate or BudBuilt crossmember.
2007 Ti FJC
TCao is offline
Old 02-26-2007, 08:49 PM   #4 (permalink)
Nevada_FJ's Avatar
Member Number: 3784
I got the center skid and the cross member right now. I should have the others soon weather over the pass is slowing Fed Ex from Sacremento. I am sure the rest of the hareware and install instructions will be in these boxes for the front and the aft sections. I know that it has been said before and I will say it again man these things are great I can't believe the difference from stock. I have been out in the garage three times tonight just to pick them up and admire them.
I may get some feedback from this but, I would recommend these before my DR lift. I think that the insurance that they will provide will be a great comfort.
Thanks
Old 02-26-2007, 10:49 PM   #5 (permalink)
geoff's Avatar
Member Number: 7410
Call Bud. He has instructions he can email you.
geoff is offline
Old 02-26-2007, 11:12 PM   #6 (permalink)
OlyWaFJ's Avatar
Member Number: 3762
Bud is great to work with, give him a call in the morning. He walked me right through a challenging part with me right over the phone.
President - TLCA South Sound Cruisers
2007 BC, 4x4 AT,Rear Locker, A-Trac, Terra Grapplers, BudBuilt Skids, Stubbs Sliders,
OME Med/Med, ARB Bull Bar, IPF Fog lights, ICom IC-208H 2M/440
TLCA# 16640
OlyWaFJ is offline
Old 02-27-2007, 08:11 AM   #7 (permalink)
Land Use Mod
k9crazy's Avatar
Member Number: 3833
Hey, those are my skidplates! Cool!
They were VERY easy to install. I didn't have any directions and I didn't have any issues what-so-ever!
Heather
Titanium '07 FJ Cruiser - #1774!
Red and White 1973 FJ55
TreadLightly! Master Trainer
k9crazy is offline
Old 02-27-2007, 10:21 AM   #8 (permalink)
ruebarb's Avatar
Member Number: 1493
Will this fit with any of the aftermarket bumpers?
ruebarb is offline
Old 02-27-2007, 11:06 AM   #9 (permalink)
TCao's Avatar
Member Number: 940
ruebarb previously said: View Post
Yes, they should work with aftermarket bumpers since the front skid plate mounts to the same frame crossbar as the OEM skid and the BudBuilt plate is also slotted to accommodate coilovers with swaybar spacer blocks. I have FabFours front bumper.
2007 Ti FJC
TCao is offline
