Old 02-28-2007, 09:21 PM   #1 (permalink)
daToy's Avatar
Member Number: 8031
Loctite Rock Rails?
Should I Loctite the Rockrail bolts? Also, are there any suggestions to help prevent rust from forming between the rockrails and the frame?
Tomas
KC0NRZ
My other ride is a Scott Spark Ultimate
VooDoo Blue, 6M
Panorama from the top of My FJ at Last years Summit.
VVVVVVVV
daToy is offline
Old 02-28-2007, 09:30 PM   #2 (permalink)
Banned
Member Number: 9445
Re: Loctite Rock Rails?
No you shouldn't and paint.
AussieFJ40 is offline
Old 02-28-2007, 10:23 PM   #3 (permalink)
daToy's Avatar
Member Number: 8031
I'll just use primer on the facing of the mounting plate. I was also thinking of making some rubber gaskets to go between the rock rail the the frame. Thoughts?
Tomas
KC0NRZ
VooDoo Blue, 6M
VVVVVVVV
daToy is offline
Old 02-28-2007, 10:44 PM   #4 (permalink)
5280FJ's Avatar
Member Number: 7663
tdawson previously said: View Post
Would promote flexing...
5280FJ is offline
Old 03-01-2007, 06:51 AM   #5 (permalink)
TCao's Avatar
Member Number: 940
I would use anti-seize on the threads and torque the bolts down. The rock rails need to be structurally tied to the frame so gaskets between the rock rails and frame is not a good idea. Paint should be OK for corrosion prevention since there should not be any sliding between rock rails and frame attachment points.
2007 Ti FJC
TCao is offline
Old 03-01-2007, 08:43 AM   #6 (permalink)
Go4aRyd's Avatar
Member Number: 2937
Good Advice - and I would be sure and use a torque wrench to be sure the botls are properly tensioned. You don't want them under-tensioned and it is easy to do for a couple of the bolts who are in a location that makes them a bit more difficult to get leverage on.
Go4aRyd - Voodoo Blue, AT, TRD wheels, BFG A/T KO, WHITE bezel, Demello sliders, Gobi Stealth rack&ladder, PIAA lights, Lowrance Baja 480C, dual battery.
Go4aRyd is offline
Old 03-01-2007, 08:57 AM   #7 (permalink)
OneManBanned's Avatar
Member Number: 4316
stainless bolts too they still look good after a couple years
OneManBanned is online now
