I bought a EP9000 as a part of the Superwinch group buy. Once I ordered that it only seemed reasonable that I would need to mount it instead of carrying it around in the back of the FJ!
I liked the looks and the weight of the All Pro bumper so....
Then came the adventures of mounting everything up.
First comment - Both the bumper and the winch are well built products. Excellent fit and finish on both. Functionality is the next test!
Second comment - The Superwinch EPI model will not fit. You need to use the EP model as this one allows the solenoid to be remote mounted.
The All Pro bumper was designed for the Warn winch. The Superwinch has the same footprint as the Warn so that worked fine. The differences come in with the extremities. The free spool selector and the control box are different and modifications are required to fit these.
Like the Warn, the right end of the winch needs to be "Clocked" to allow access to the fre spool selector. When looking at the end of the winch clock it to the 8:00 position (just below center). The hole that it looks out of needs to be modified to allow full access to the selector. Actually, if you don't provide access you can't turn it.
The All Pro design had the Warn control box mounted in its entirety inside the bumper. The Superwinch control box does not fit well inside. I elected to simply lose the box, mount the solenoid inside and mount the control cable plug directly to the surface of the bumper. I'm real pleased with this by the way.
The other difference is the mounting bolt direction of the superwinch. Evidently, the Warn bolts are accessible from the top. The Superwinch bolts are accessed from the bottom. The nuts are trapped in the winch housing.
Therefore you need wrench access from the bottom to tighten them up. There is not clearance to fit a wrench on the front two bolts so I had to drill two new access holes to reach these bolts.
