Old 04-29-2006, 08:01 PM   #131
JimmyHoops's Avatar
Member Number: 1812
Re: New FJ....and custom sliders
JohnGalt previously said:
Yep. Just wanted to say I'd seen the price less expensive than MSRP and/or the price Kansas was referring to. Not a functional comparison.
Fair enough!
Missin' my FJ 40 But lovin' my FJ Cruiser
Rides:
'03 Audi A6 2.7 Bi-Turbo, Silver
'07 FJ Cruiser, Voodoo Blue, M/T6 Option#2 w/Rack
JimmyHoops is offline
Old 04-29-2006, 11:28 PM   #132
Freewheeling Frank's Avatar
Member Number: 1052
Aj at bentup told me he would make them stick out less if that was what I wanted.
If I get them, I will get them uncoated and rattle can them with Rustoleum or maybe even undercoating. Not too worried about them being real pretty. Plan on scraping them up!
looking for my brother's cat...
Freewheeling Frank is offline
Old 05-04-2006, 05:10 PM   #133
L8Apex's Avatar
Member Number: 2080
Does anyone know if a flat step/tread section can be added to the bentup sliders? I want to use the rails as a step in addition to protecting the underside of the truck from obstacles. From the pics of the bentup rails, it looks like someone could easily slip off the rail and get a foot caught between the 2 bars. This wouldn't go over well if it's my mother-in-law that slips while climbing in the truck.
I know some rails have a flat section "dented" into them under the doors. Others have a step welded on in this area. Can this be done with the bentup rails?
The Tank (aka "RED PILL") : 2007 FJ Cruiser, 4x4AT, black cherry
- Expedition One bullbar bumper
- Expedition One rock sliders
- BudBuilt skids (front, mid, TC, crossmember)
- Bilstein 5100 front struts, set at 1.75" lift
- GoodYear Wrangler Silent Armor tires 275/70/R17
The Fighter Jet: 2001 MR2 Spyder, silver
- 2ZZ motor/6spd swap
- TRD Sportivo suspension
- 3.0 Racing chassis bracing
- JDM Toyota hardtop, soft-top delete
L8Apex is offline
Old 05-16-2006, 01:44 AM   #134
bigbill25's Avatar
Member Number: 1293
A) Back from Costa Rica
B) Installed my BentUp sliders
I think you guys are more interested in B... The install was straight forward. All the bolts were high-grade 10.9 stamped stuff. I did the install solo. Only one issue:
The bracket holding the brake line (circled) must be removed. This is so the farthest back slider bracket can attach to the mounting points (arrows). The factory rock rails don't have a solid plate like this so the line does not need to be moved.
With the install completed, you can see the brake line 'hovering' above the mount. It seemed possible to reattach the bracket, but it would put a lot of stress on the brake line where it crosses over the slider. I decided to let it 'float' as the better of two evils.
Mounted up!
Lower angle.
Trying to show the 'stick-out-ness'
Conclusion: I think they look great. No complaints from me on that. They are easy to hop up onto for roof rack purposes. The back of your pants will most likely keep them polished every time you step out
--Bill
(Sold) 2007 FJ Cruiser, 6-Speed, Voodoo Blue, FE, CQ, UR, GY, CF, 3T, EL
Added: 2Q, 6D, WL, DH, V5, Bentup Sliders, Horn, CB, ToyTec Lift, Gobi Stealth Rack
bigbill25 is offline
Old 05-16-2006, 07:06 AM   #135
Thai's Avatar
Member Number: 1669
Bill, you may want to use zipties to hold the brake line more securely. For my slider on my G, i use the skateboard friction tape so that your passengers (and you) won't slip off the nerf bars when stepping into your car.
Thai is offline
Old 05-16-2006, 08:42 AM   #136
billthomson's Avatar
Member Number: 1124
Mucho thanks for the pictures! They do look really good installed.
The brakeline has been one of my concerns with getting these sliders. I think Andy mentioned that in his final install he did replace the brake line, but when I was looking at mine it seemed like it would be really tight if I did this. I do think I'm going to order some of these though
How do you like the amount of "stick-outiness"? Curious if you think it would be worthwhile to have about an inch less. Also, did you specify the gloss coating, or was this the only one that bentup was using?
billthomson is offline
Old 05-16-2006, 09:06 AM   #137
Banned
VooDooBlueDude's Avatar
Member Number: 2230
Send a message via ICQ to VooDooBlueDude
Angry Re: New FJ....and custom sliders
VooDooBlueDude is offline
Old 05-16-2006, 09:59 AM   #138
bigbill25's Avatar
Member Number: 1293
Hmmm. Good idea. [Thinking out loud:] I might reinstall the brake line bracket and then ziptie the line to the top of it, that way using the brass fitting so the zipties don't cut into the rubber...
The aren't slippery right now. I'll have to check after a good rain (should be any day now in Portland...). I like the gloss look, so I would rather not add a friction modifier...
--Bill
Old 05-16-2006, 10:04 AM   #139
bigbill25's Avatar
Member Number: 1293
It's a tough call on the stick-out-ness. Right now, they are easy to hop up on for roof-rack checking and for use in ingress/egress. An inch in, they would be a bit more like toe holds. However, it would save the back of your pants a bit... Compromises. As far as looks go, I think they look great with this level of pop-out...
For the coating, I only specified a powder coat and this is what came. I like the gloss though, so no regrets.
--Bill
Old 05-16-2006, 11:08 AM   #140
caliFJ's Avatar
Member Number: 295
bigbill, what was the final price after sliders and powdering?
caliFJ is offline
