Old 03-23-2007, 09:38 AM   #1 (permalink)
ruebarb's Avatar
Member Number: 1493
Jack Stand Recommendation
Which type of jack stand is better/preferred for working on the FJ and/or changing a tire?
HUSKY
3 Ton Double Lock Jack Stands
or
HUSKY
3 Ton Suv Jack
Thanks
ruebarb is offline
Old 03-23-2007, 10:48 AM   #2 (permalink)
mikey's Avatar
Member Number: 2806
Re: Jack Stand Recommendation
Jack stands,never rely on the jack to hold the vehicle if you are working on,around 'specialy if you are under it.
mikey is offline
Old 03-23-2007, 11:26 AM   #3 (permalink)
Rmplstlskn's Avatar
Member Number: 9808
BOTH! Used together...
One gets the vehicle up enough to place jack stands. Did I misunderstand your two choices?
Back in my younger (aka foolish & poorer) days, we would use CINDER BLOCKS rather than jack stands. Now, wiser, knowing how cinder blocks can crack and split relatively easily, I would NEVER go under a vehicle without STEEL jack stands properly placed.
Rmpl
Ti FJ still basically stock. BFG's all around.
What Would Y'shua Do?
Rmplstlskn is offline
Old 03-23-2007, 11:39 AM   #4 (permalink)
gomerpyle's Avatar
Member Number: 6746
Don't ever crawl under a vehicle up on just a jack. The seal that holds the fluid in place on a hydrualic floor jack costs ten cents. Would you want to put your life in the hands of something that cheap?
Quagmire, isn't country supposed to have an "o" in it?
Nope
gomerpyle is offline
Old 03-23-2007, 11:58 AM   #5 (permalink)
ruebarb's Avatar
Member Number: 1493
I plan on using ramps and chocks if I am under the FJ. I wasn't sure if one type was better than the other on the jacks, but the idea of using the hydro to get the jack under makes sense.
ruebarb is offline
Old 03-23-2007, 12:03 PM   #6 (permalink)
gomerpyle's Avatar
Member Number: 6746
ruebarb previously said: View Post
Glad to hear it. I used to assume that everyone knew not to trust a jack, that is until a buddy in high school almost cut his hand off with a license plate after the truck slipped of the jack.
Nope
Old 03-23-2007, 12:20 PM   #7 (permalink)
Spike Strip's Avatar
Member Number: 188
Buy the best jack stands you can afford and the best Jack. ALWAYS use both together when working on a lifted vehicle and even use redundant jack stands.
When I was in high school I watched in horror as a friend's '68 'Cuda slipped off the jack and SINGLE stand and pinned him underneath .... Fortunately, we got it off him quickly, but he still TWENTY-TWO YEARS later, has the scars on his neck from a hot exhaust pipe !
That taught me very well to be extra careful.
Spike Strip is offline
Old 03-23-2007, 01:06 PM   #8 (permalink)
ruebarb's Avatar
Member Number: 1493
Spike Strip previously said: View Post
Damn that sucks, lucky though.
I'll be working a cold system, I'm not taking any chances and 40 for the high tomorrow, I'll be cold too while on the ground.
Thanks everyone for the safety tips
ruebarb is offline
Old 03-23-2007, 01:10 PM   #9 (permalink)
mikey's Avatar
Member Number: 2806
Don't forget to bundle up and wear a touque.
mikey is offline
Old 03-23-2007, 02:18 PM   #10 (permalink)
Son of a Son's Avatar
Member Number: 3191
Send a message via MSN to Son of a Son
Oh and make sure your jack can lift pretty high. many of the ones I have had are ok for cars but when you get into things like the FJ with lots of suspension flex they just can reach high enough.
Son of a Son is offline
