Tranman previously said:
Topless: you mentioned that the coilovers are height adjustable in the front. Do they adjust in the back as well? Is this system similar to the range rovers?
Also what is the relative price difference for a spacer kit installed versus a coilover and new rear springs and shocks?
I've heard that some people are also saying that with the coilovers and rear springs and shocks, the ride in the tacomas are better than stock. Assuming this would carry over onto the FJ as well.
its unlikely you will find an adjustable kit for the rear unless you are switching to airbags where you can adjust the air pressure to change ride height. the rear has seperate coil springs and shocks, whereas the front is a coil over shock (coilover) which usually have adjustment collars built in. I cant comment on range rovers as i know virtually nothing about them.
Almost all spacer kits are far overpriced, simple because people dont know any better. essentially all they are is a machined "hockey puck" with holes in it for the upper coilover mount, some additional hardware, and usually new shocks. hardly something i would willingly pay almost $1000 for. going the "good" route will cost you more, but you will actually get performance gains out of the deal too. usually the springs and shocks are designed for off-road use and are made by premium, specialty mfrs. The kit i have seen for tacomas runs around 1200 for the full kit, i havent looked into anything for the 4runner, but pricing on those should be virtually identical to the FJC as the kits will use almost identical components. expect something in the range of $1500 or so. if they want to charge you more (than a comparable 4runner kit) because its a brand new kit, just designed, etc. they are blowing smoke up your you-know-what as all they really did was modify the 4runner kit to work with the FJC, which should make it cheaper, if anything.
as far as the install goes, i dont know how mechanically inclined you are, but these are amoung the easiest to install, provided you have basic shop tools in your garage, such as hand tools, jack stands, a floor jack, etc. if you pay someone to do it it will cost significantly more, i would estimate $500-ish? i really dont know as i do all the work on my truck myself. If you do the install yourself you will want to get an alignment immediately after you finish getting everything installed and adjust the ride height, add new tires and such as any kind of lift will throw it off a bit.
