Old 05-14-2007, 11:15 AM   #1
The Laughing Moderator
LandCruiserSteve's Avatar
Member Number: 8627
Warn Winch Bumper install - pics
Not a difficult installation; just time consuming. About 4-5 hours including the installation of the winch itself.
It can easily be a one-person job . . . . all the way up to the point where you need to grab a neighbor to help lift the 140 beast up onto the mounting brackets.
Factory bumper and bezel removal was a piece of cake. About 10 minutes to strip off the entire plastic front end.
The majority of time is spent attaching the many supplied brackets, bolts, washers and nuts prior to actually hanging the bumper.
The fit tolerences are very tight, so some tweeking is required to get them aligned properly. Of course, all nuts and bolts are to be left untightened until the bumper is on and aligned.
I didn't take photos of the step-by-step process since Warn's instruction manual has fantastic close-up pics of each step. (I'll try posting that manual later in this thread.)
After the bumper is hung on the exisitng bumper frame brackets and the six additional Warn brackets, you have to throw some brute force into aligning the bumper. The Hi-Lift came in handy to nudging up one side or the other prior to nut and bolt tightening.
Warn did their homework when designing this bumper for the FJ. Once it was installed, there were no gaps, wierd protrusions nor a look that made it look like it was made universally for some other vehicles.
The bottom of the bumper conforms perfectly to the factory skid plate, almost as if they were one continuous piece.
Once the bumper installation was complete, it was a breeze dropping the Warn M8000 into the open top tray. The actual winch installation took less than 15 minutes.
Rather than mounting the winch solenoid box on the winch itself, I ended up putting it inside the engine compartment. That required a couple of additonal 6-foot 2 AWG battery cables and fabricating a bracket that attached right behind the fuse box.
The end result: Perfect (if I do say so myself).
Total front end drop after bumper and winch installation: 1/2"
The OME heavy 886 definitely do their job.
Before bumper and winch:
After bumper and winch:
Steve
The '07 Kiroi Hako
'78 FJ40
TLCA #6727
UFWDA
LandCruiserSteve is offline
Old 05-14-2007, 11:20 AM   #2
RESE's Avatar
Member Number: 7827
Send a message via MSN to RESE
Re: Warn Winch Bumper install - pics
Hottest looking bumper out!
RESE
TLCA MEMEBER
RESE is offline
Old 05-14-2007, 11:53 AM   #3
timbo2's Avatar
Member Number: 3828
Great Job and great looking bumper! It has been my first pick since I've statrted comparing. Just one question: What is the approach angle? Has it gotten better or worse? It could be the pics, but it looks like the Warn actually protrudes a little farther out from the body. I love the looks and price, but I also want improved angles. Thanks, Timbo2
timbo2 is offline
Old 05-14-2007, 11:59 AM   #4
chewey46's Avatar
Member Number: 292
Any plans on getting Warn's rear bumper??
That would be sweet getting a rear bumper to match!!!
[YOUTUBE]
http://www.youtube.com/watch?v=ZPzUx...eature=related
A cross between quasimoto and the elephant man..... But only the good parts!!!!!
Hello chewey46 it appears that you have not posted on our forums in several weeks, why not take a few moments to ask a question, help provide a solution or just engage in a conversation with another member in any one of our forums?
chewey46 is offline
Old 05-14-2007, 01:49 PM   #5
446cube's Avatar
Member Number: 2002
Looks good, gotta like the ease of getting to the winch.
The funny thing about getting pistol whipped...
446cube is offline
Old 05-14-2007, 04:09 PM   #6
Member Number: 8627
chewey46 previously said: View Post
No immediate plans. Would like to see one in person before I decide. And, hopefully it wouldn't be adding another couple hundred pounds. (I was already feeling my gas mileage taking a dive just by lifting the front bumper on there. )
Steve
The '07 Kiroi Hako
'78 FJ40
TLCA #6727
UFWDA
Old 05-14-2007, 04:20 PM   #7
Member Number: 8627
timbo2 previously said: View Post
There's obviously going to be a protrusion by putting on any winch bumper (to accomadate the depth of a winch). But, the winch mounting surface sits very high, actually resulting in a substantially improved approach angle. So much so, that it exposes the factory front tow hooks out in the open, rather than tucked in behind the OEM plastic bumper.
Pre-bumper install:
Post-bumper install:
Steve
The '07 Kiroi Hako
'78 FJ40
TLCA #6727
UFWDA
Old 05-14-2007, 04:29 PM   #8
Member Number: 8627
446cube previously said: View Post
Ain't that the truth.
Steve
The '07 Kiroi Hako
'78 FJ40
TLCA #6727
UFWDA
Old 05-14-2007, 07:21 PM   #9
rbc24123's Avatar
Member Number: 10926
Nice setup....
How much did your mileage take a hit?
07 FJ Titanium AT5 4WD CQ,Up#2,OEM Rack (Born: 04.07.07)
Mods [done]: Demello sliders, Cobra 75WXST+Bandi, M-PAC Side
Mods [to do]: Tires/Wheels, ICON Suspension+UCA, Front Bumper+Winch+fogs, Extra lights, 2m radio, Blackout handles+mirrors
____________________________________________
member: treadlightly!
rbc24123 is offline
Old 05-14-2007, 07:35 PM   #10
eljugador's Avatar
Member Number: 9631
With the controller box inside the hood, won't it be difficult to operate the winch from inside the vehicle? You'll have to have the hood up -- at least a little -- then it will be bouncing all over and chewing up yor remote chord.
1/20/09 -- The End of an Error
eljugador is offline
