daPitbull previously said:
So how does the tire carrier work? You swing out the tire carrier the same direction as the door? Is it possible to scratch/dent/damage the door by hitting the carrier when opening the door? Looks badass though...and heavy
e
Well I will go check, the tire carrier opens way out as the door stops so there should not be a issue.
Final weight not sure will put the final version on the scales in 6 weeks.
My rear springs did not move I did measure.
Departure angle is no greater, but I like the bumper, no plastic.
The final wings will be a little larger filling the gap you see when the door is open ortherwise they did a great job.
