Old 10-04-2007, 10:54 PM   #261 (permalink)
Awesome Guy!
Shadow-Warrior's Avatar
Member Number: 3913
Re: SCUBA Driver Rear Differential Breather MOD
thugasaur previously said: View Post
i was meaning more about water coming in through the new set up if god forbid you get too deep in the wet stuff and stay there kinda like a fail safe
If your that deep, you have alot more problems to worry about than a little water in the diff
TLCA Member : #18084
Honorary AZFJ Club Member
Honorary SoCal Club Member
FJ Cruiser Club Member
Meet The RAPTOR 2007 TRD SE
Shadow-Warrior is offline
Old 10-06-2007, 02:41 PM   #262 (permalink)
cnynrat's Avatar
Member Number: 8138
Shadow Warrior:
Cnynrat reporting for duty in the Scuba Driver Brigade.
Think this mounting location might reduce the chance of the dreaded bulge?
Dave
Member Tread Lightly
Ti Metallic
cnynrat is offline
Old 10-06-2007, 04:26 PM   #263 (permalink)
TJ Cruiser's Avatar
Member Number: 3134
I use a fuel filter, never been used, that has been rolling around in my tool box for years.
I ordered the camry union but couldn't wait so until it comes in I got my parts at Home DePot
Black Diamond FJC 4x4 AT Revtec 3" Lift, Tires-33x12.5R20 TOYO Open Country M/T....Wheels:Gear Alloy, 713 MB, Double Pump, 20 x 9 Kicker 1000watt amp 2-10" woofers and all new speakers. Metal Tech sliders, CAI, Borla Dual Exhaust, Scuba Driver mods, Cobra 75, Bandi mount, Firestik Firefly 3', Garmin 478 GPS with weather radar & XM Radio.
www.sun1.netwww.dirtycruisers.com
my scuba driving video-http://www.youtube.com/watch?v=k7DPRFMBXDc
TJ Cruiser is offline
Old 10-06-2007, 06:35 PM   #264 (permalink)
Member Number: 11952
OK, I decided to go ahead with this mod, and just finished obtaining parts today. But, in planning the breather/filter install for the engine compartment, noticed the front breather caps, located just back of the oil filter.
Wouldn't these too create a vacuum when water hits the front differential? So, would it be a good idea to relieve the vacuum neg. pressure by changing these over to a freeflow filter, like that for the rear diff/R locker? Yeah, the front ones are already higher, but couldn't the neg. pressure draw in water through some seals underwater up front too?
Anyone? Thanks in advance...
rons8888 is offline
Old 10-06-2007, 06:41 PM   #265 (permalink)
FJoel's Avatar
Member Number: 4197
rons8888 previously said: View Post
Not quite sure what you mean... the seals are meant to hold hot diff fluid in, so I don't see them letting cold water in. Still I agree with you that a change to a free flow filter may be a better choice.
Experts? What's you opinion please? Maybe tie the front into the same filter via an extension?
Full-time machinist. Part-time pilot.
www.ellisprecision.ca
FJoel is offline
Old 10-06-2007, 06:56 PM   #266 (permalink)
thugasaur's Avatar
Member Number: 691
Send a message via AIM to thugasaur Send a message via Yahoo to thugasaur
you could make a manifold with the breather at the end
1.Chefj's Little known facts: Thugasaur tracked down, strangled, and gutted the Snuggle fabric softener bear because he once had a towel that was...well...not so soft.
2.STOP DRINKING THAT YELLOW KOOL AIDE IT MESSES YOU UP INSIDE!
"Church" V2.0
2007 Voodoo 5AT 4x4
______________________
AFE cai , piaa extreme super whites , demello front skid plate and rock rails and aero flow lens covers , all-pro front sway bar links
thugasaur is offline
Old 10-06-2007, 07:05 PM   #267 (permalink)
DEWFPO's Avatar
Member Number: 7505
Most auto supply stores carry small plastic vaccum manifolds that you could plug everything into. The most common ones have 3 & 4 ports.
DEWFPO
Engine Block Heater, '08 Cyclone Pre-Filter, Dual horns, Phillips Osram 70W/65W H4's, RockBlocker and 3M Clear Film, Toyota RearSight Backup Camera.
"Enjoying the Journey"
DEWFPO is offline
Old 10-06-2007, 07:08 PM   #268 (permalink)
Awesome Guy!
Member Number: 3913
The ones up front that Toyota has already relocated for you I think will be fine, you can if you want, it will help. The ones in the rear are a little different story. They sit very low on the rear which will pick up alot more debris that could get up inside the stock cap and keep the breather cap in the open position that would alow water to be sucked inside. The ones under the hood are pretty much clear of the amount of mud you would get in the rear. But again, it dosn't hurt to be more efficient up front under the hood too. In the end it's your call, if you plan on running alot in the water and mud, I would have to say yes. On a side note, those of you that are runing the open breather like I show, treat it just like a K&N filter, it is basicly, it's cloth with wire mesh. I spray mine with a light coat of oil to keep any water from entering the open filter. I hope this helps
Old 10-06-2007, 07:14 PM   #269 (permalink)
Awesome Guy!
Member Number: 3913
cnynrat previously said: View Post
Shadow Warrior:
Looks great, PM me with your name and address and I'll send you out a sticker
You too TJ Cruiser, PM with your Info
[quote=rons8888;637787]OK, I decided to go ahead with this mod, and just finished obtaining parts today. But, in planning the breather/filter install for the engine compartment, noticed the front breather caps, located just back of the oil filter. quote]
When your done post some pic's and then PM with your name and address, I'll send you a sticker
Old 10-06-2007, 08:37 PM   #270 (permalink)
bandi's Avatar
Member Number: 2261
Got mine Done today... Finally a few miniutes to put
it together, well, since I was not even sure which
way I was going to go, it took a little longer on mine,
but the wifes will be a sinch' tomorrow... I did take a
bunch of picts, but my main house PC vid card just
smoked and it's too dark to search the shed for my
spare, so tomorrow hopefully... I did mine just a tad
different then most, so I will do a write-up on the
bandi build thread...
[edited] Quik Picts Added...
I ran the lines so that the follow OEM lines, and
ended them at the top of the fuel fill cavity...
Here is the connects at the Axle...
and Here is where the OEM vents were located too...
[[[[[[[[[ DEMELLO FlatTop Bumpers ]]]]]]]]]
The "Bandi Mount" From ALL-PRO OFF-ROAD
bandi is offline
