Old 02-09-2008, 06:29 PM   #501
stringmachine's Avatar
Member Number: 7766
Re: SCUBA Driver Transmission, Transfer Case, Rear Differential & E-Locker Breather M
just got new batteries for my camera i will go out and snap a shot of them.
stringmachine is offline
Old 02-09-2008, 06:36 PM   #502
Member Number: 7766
Old 02-09-2008, 06:38 PM   #503
On Pilgimage
Member Number: 2479
Re: SCUBA Driver Transmission, Transfer Case, Rear Differential & E-Locker Breather MOD
That looks like it's right next to your alternator, so they are already high enough.
Dragon is offline
Old 02-09-2008, 06:38 PM   #504
Member Number: 7766
mine is like this from the factory. is there some different than others?
Old 02-09-2008, 06:41 PM   #505
On Pilgimage
Member Number: 2479
Those are not the ones you need to relocate. There are four others.
Dragon is offline
Old 02-09-2008, 06:43 PM   #506
Member Number: 7766
never did claim to be the sharpess knife ya know. but if i did not ask . i would still be scratching my ,a head
Old 02-09-2008, 06:45 PM   #507
On Pilgimage
Member Number: 2479
I scratch mine continually. ...but eventually I ask enough questions and get the right answers.
Dragon is offline
Old 02-09-2008, 06:47 PM   #508
Member Number: 7766
Dragon thanks Buddy! i will start over tomorrow weather permitting.. thx
Old 02-09-2008, 06:53 PM   #509
CactusJK's Avatar
Member Number: 1157
I have located both the 1/8" line and 1/4" line with the plastic end. There is lots of slack on the 1/8" line. The 1/4" line is tight. I wish that I could release the 1/4" line from the hold down so that I could raise it up a little to work the 1/4" adapter in. Has anyone been able to lift up on this line out of it's bracket?
Even with slack how did people securely fasten tie wraps around the connections? I assume no one used hose clamps like in the back?
Thanks for all the help!
stringmachine previously said: View Post
I see the 2 lines, didn't find the tc yet, but when i do i do this one and the rear diff, as shown(e) Locker, and the other 2 on the driverside also correct?
CactusJK is offline
Old 02-09-2008, 06:56 PM   #510
On Pilgimage
Member Number: 2479
CactusJK previously said: View Post
Get the cinch wrap just about the right size and slip it on the existing hose in the engine bay.
Spray the end of your connector with WD40 so it slips into the existing hose easily (have the new hose already on the other side of the adapter). You should be able to cinch down the tie with your thumb pretty damn tight.
...glad you found them both.
Dragon is offline
