Re: SCUBA Driver Transmission, Transfer Case, Rear Differential & E-Locker Breather MOD
This may have already been mentioned, but I'm too lazy to go back through 13 pages
It is possible to reach the AT and transfer case breathers from inside the passenger wheel well. Turn your wheels all the way to the drivers side, then remove the rubber sheet that is held inside the wheel well by trim fasteners.
With a little wiggling around, you should be able to sit up between the wheel and the frame and reach across to the breathers.
This does not make it easy - but it may be easier than going in from the top.
Did you completely remove the 1/4" line and install a new one? Any detail on the 1/4" line install would be greatly appreciated.
w5wi previously said:
Mike,
First, thanks for this thread! Thanks to Jim 007FJ for identifying the transmission issue and where the vents are located!
Today I completed the full Scuba Driver Mod including the transmission and transfer case vent relocations! Mike, you forgot to mention how much blood is let sliding your left arm down past that *&%! bracket...
Enclosed is the photographic proof of my install. I'll PM you with my address for a sticker. If you still have them!
Please note that the vent line is not as tight as it shows in the photo... I took the photo and then installed the tie wraps.
Transmission and transfer case vents relocated
transmission and transfer case vents removed from top of bell housing
Differential and elocker vent lines moved (differential vent line is not that tight now!)
Now, to get warmer weather and a 4 1/4" drill bit to install my snorkel!
How did you remove the hose from below?
SoonerFJ previously said:
I got mine completed today and it was much easier for me to disconnect the transmission breather hose from its origin on the transmission instead of trying to remove the breather cap from the hose. Even after I got the hose off, I couldnt get the cap to budge. It took all of two minutes to remove the other end of the 6 inch hose from below....and I kept the skin on my arms this time.
stringmachine previously said:
Those two existing vents on the driver's side of the engine compartment on the 5AT's are for the front differential and the front differential actuator. The 6MT's don't have the actuator vent since they are full time 4WD.
DEWFPO
DEWFPO
thanks dew, So all i need to do then is the rear diff/elocker actuator and the tranny correct?
Made even easier if you just pop the wheel off (on stands, for safety). Great tip!
Stringmachine!?!? you listening?
-Matt
2008 AT 4x4 Voodoo Blue FJ with not enough trail pin-striping
