Old 06-06-2008, 04:24 PM   #641
Super Moderator
Shadow-Warrior's Avatar
Member Number: 3913
Re: SCUBA Driver Transmission, Transfer Case, Rear Differential & E-Locker Breather M
Read post #1 it has all the info with pictures, that is what it's there for.
TLCA Member : #18084
Honorary AZFJ Club Member
Honorary SoCal Club Member
FJ Cruiser Club Member
Meet The RAPTOR 2007 TRD SE
Shadow-Warrior is offline
Old 06-07-2008, 05:48 AM   #642
Member Number: 17872
Oh believe me, I read and re-read that page so many times I lost count. I guess I am just not seeing what I am supposed to be seeing. I'll just have to find another 08 FJ owner in my area who knows where and what to look for. Thanks anyway.
Mike H is offline
Old 06-10-2008, 08:51 AM   #643
FlyNdrive's Avatar
Member Number: 2715
With all the posting about my transmission I think I forgot to post piss of the rear breather......
A Bruisers dad put together this fitting for the breather filters so that when you go to tighten the hose clamps around the filter with the hose inside it will not cause the hose to buckle.
Here is the "T" Connector that we rigged. I was unable to find a 1/4 X 1/4 X 1/8, so I went with a 1/4 X 3 and uses a reducer of the locker hose.
used a 1/4 1/4 1/4 tee instead or a 1/4 1/4 1/8
-Ben
Chairman of the Board FJ Bruisers 2007 FJ in Sun Fusion FJ, CP #2
ARB Bull Bar W/Warn M8000 & IPF's, ARB Rear Bumper W/Warn M8000 (both W/in-cab switch) and swing out tire carrier, OME 3" lift, Safari Snorkel, Eclipse AVN GPS,DVD,CD,Sirius & B/U cam. AR Craters, W/ McT 35" MTZ's, ARB Rack W/ ARB Simpson II tent, ARB Sliders, VIAIR 450 & tank, Dirty Parts 2 Battery W/ 2 Optimas, All-Pro skids, U&L links, A-arms, Cobra 75WX,ScanGuage 2,Toshiba Tablet PC W/ Topo USA 6 on A2A mount.
FlyNdrive is offline
Old 06-30-2008, 03:11 PM   #644
Member Number: 17545
I have read hundreds of posts in probably 2 dozen threads on the scuba mod. I am quite comfortable with the rear diff and locker. I am equally comfortable with ADD and front diff. I have no idea how I am going to do the AT and transfer breathers.
How the hell did you guys get there? From below I can get one hand on top of the housing, but I cant tell what I am touching, never-mind swap out anything. From above I can see the top of the bell if I am looking from the passenger side downward at a 45, and if I climb up into the engine bay I can peek over the top and look down, but that is badly. I'm 6'3" with long arms. I have no idea how you guy get in there unless your pulling tons of parts out. And since I cant get in there, I'm not convinced I know where the existing breathers are.
Can anyone enlighten me? Zoomed out and zoomed in photos of you actively sticking your hand in there and touching the breathers (or their hoses) would be ideal. Barring that, some text written for my 3rd grade understanding level would suffice.
Thanks.
Haff is offline
Old 06-30-2008, 03:15 PM   #645
Super Moderator
Member Number: 3913
You have to get to the AT breather from up on top along the passenger side inside the engine bay. It on top and forward towards the engine. You can't see it by looking down, you have to feel it,, then grab hold and lift it up, you will see a white plastic sap on the end of the hose, thats the AT breather.
Old 07-03-2008, 01:30 PM   #646
FJ BOB's Avatar
Member Number: 13541
Send a message via MSN to FJ BOB
HELLO I was looking around the store for parts to do the Mod for this I did see a air line for air guns with a 3/4 fitting Is this the same size nut for the rear diff breather ?
If so I really think that a flex hose would look better then the rubber black ones you have in the pictures,, Don't get me wrong I think you have done a great job the way you have done it I just like the flex line because it comes in different colors and is flexable.
FJ BOB is offline
Old 07-03-2008, 01:35 PM   #647
Super Moderator
Member Number: 3913
FJ BOB previously said: View Post
This not about "Looks", It's aboout function. Use what ever you want, be for warned, it needs to be heavy duty because it's under the vehicle where wear and tear is. If you use something that is more thinner, you take the chance of it breaking down then having some serious problems. Do what you want.
Old 07-08-2008, 12:05 PM   #648
Member Number: 18658
Shadow,
Thanks for the great post! I completed the e-locker and diff breather relocation to the jack storage area as others have done. I will post pics shortly (do you still have stickers?)
I have an 08 and could only locate the transfer case breather. The AT breather on '08's is attached to a bracket fitting on the tranny. I gave up and had the local dealership perform the relo. The tech was able to remove and relocate the entire bracket onto the inner fender along with the xfer case breather.
Thanks again,
Mike
2008 TT, TrailGear Sliders, TRD CAI, Scuba Mod, M-Pac Side and Rear, All-Pro e-locker guard, All-Pro shock skids, Powertank, Midland 75-822 & Bandi, Gobi Stealth, Icon Stage One, Light Racing UCA's, Digger Upper/Lower Links, Toytec Diff Drop, Demello LCA skids.
mwmac is offline
Old 07-09-2008, 10:52 AM   #649
Here are the pics of my scuba modded '08 with the new style AT breather.
scuba-driver-transmission-transfer-case-rear-differential-e-locker-breather-mod-img_0373-1-.jpg  scuba-driver-transmission-transfer-case-rear-differential-e-locker-breather-mod-img_0374-1-.jpg  scuba-driver-transmission-transfer-case-rear-differential-e-locker-breather-mod-img_0377-1-.jpg  scuba-driver-transmission-transfer-case-rear-differential-e-locker-breather-mod-img_0371-1-.jpg
mwmac is offline
Old 07-09-2008, 02:24 PM   #650
Maglight's Avatar
Member Number: 2835
IN my truck 2007 AT I have something very similar looking to the 4th pic attached to the driver side of the engine. What is it. I figure from all the reading that it is not the AT breather or for the transfer case but it looks like the factory breathers. Anyone know what it is?
Low Country Cruiser
TLCA # 19021
http://www.fjcruiserforums.com/forums/image.php?type=sigpic&userid=2835&dateline=1180801  019
Your Current Signature Picture
Maglight is offline
