Re: SCUBA Driver Transmission, Transfer Case, Rear Differential & E-Locker Breather M
Awww heck! I'm doin' this. I just ordered the fuel-line union from Toyota and have the other parts that I need - hopefully I'll get this done by Sunday.
"GREAT GOD OF WRITING! ...MAKE A MENTAL NOTE: AIRPORTS WILL BE NAMED AFTER THIS WOMAN!"
-What Air might have said if he were a McCain/Palin supporter...
6 spd MT Voodoo Blue
Rear diff and e-locker scuba mod
CB w/ custom CB antenna mount on uppper rear door hinge
A-Trac switch installed
Custom tube bumper in the works...
stringmachine previously said:
don't forget the little filters from the auto store they will help keep a vacum from occuring in the diffs..
I got 'er done! I opted for routing the breather hose up into the left rear (jack) storage bin - less length of hose required and less to worry about IMO...
I am getting ready to do this mod.
I noticed that a couple of posts mentioned that the union on the rear diff is NPT, but no one said what size. So, since the dealer has to order this part out, what size is it??? (so I can get it at HD or lowes)..
Thanks.
07 Titanium loaded..
Current mods: scuba breathers, OME883's & Bilstein513's, BFG KM2's, Bridgestone Revos, Trailgear Sliders, K&N Drop in, 08 side visors, 35% tint, Redline gear oil, Atrac hack, mini-ITX PC (GPS & wardriving), upgraded speakers, custom rear door sub, custom air dam w/ hella spots and surf rack, grill mounted hella driving and fog lites, air horns, solar batter charger, rear 12V outlet, block heater, painted stock alloys (1 set black, 1 set graphite)..
Went ahead and did this yesterday. The only hard part was locating the breathers for the tranny and xfer case. To anyone else looking for them - they are right behind the heads on top of the bell housing. You can see them from the passenger side using a flashlight.
The fitting I used for the rear diff is a 1/4" npt, in case anyone else has the same dilema that I posted on..
I have some ideas for a snorkle of sorts to keep splash in the engine compartment from getting to the filter. I'll post pics when complete.
Thanks to all who posted previously on this topic, very informative and helpful!
The fitting that is listed as a camry fuel union is NOT a 1/4 NPT!!!!Neither is the original 1 way breather.
The differential housing is NOT tapped for 1/4 NPT!!!!
The correct thread size is 1/8 NPS!!---1/8th National Pipe Straight!
Its NOT National Pipe Taper.
Do NOT force a TAPERED Pipe threaded fitting into your housing!!!
Go to Toyota and purchase the Union as origially instucted.
NPT==== National Pipe TAPERED
NPS===== National Pipe STRAIGHT!
Compleated the Mod today!!---- Thanks!!!
Gooser
Thanks for posting. I'm not sure why people want to "Try" something different when I tried to give complete instructions in the first place to take all the work out if it for them....I don't know why someone would have posted it being 1/4 NPT, since it's all Metric in the first place should have given them a clue...you can lead a horse to water but can't make him drink.
Mike
