Old 08-07-2009, 01:11 PM   #751
bandi's Avatar
Member Number: 2261
Re: SCUBA Driver Transmission, Transfer Case, Rear Differential & E-Locker Breather M
^^^ IS the front one up against the exhaust
at some point ?...
[[[[[[[[[ DEMELLO FlatTop Bumpers ]]]]]]]]]
The "Bandi Mount" From ALL-PRO OFF-ROAD
bandi is offline
Old 08-07-2009, 01:53 PM   #752
Grendel's Avatar
Member Number: 24351
I'm thinking Bandi may be on to something here...I'd have a look and see what might be cooking on the exhaust manifold. Sounds like the rear diff is ruled out given the circumstances regarding when you smell it. Good luck on finding the root cause of your smell.
bandi previously said: View Post
IS the front one up against the exhaust at some point ?...
joenshan previously said: View Post
I dont smell it if i have the windows up and have it on inside air. I've only noticed the strong smell when i step on the gas going up hill and if the window is down.
Grendel is offline
Old 08-10-2009, 04:39 PM   #753
Mightyboss's Avatar
Member Number: 27190
You need 15' of 1/4 fuel , line but the other 2 mods you use 1/8 fuel line? is this correct? and how much line is required?
Blacked out and No were to go.....
I DONT CARE WHO YOU ARE AND HOW OLD YOU ARE, GET A COLONOSCOPY AS SOON AS YOU CAN, NO MATTER WHAT YOUR DOC SAYS !!!!
THANK YOU
facebook friend link:
http://www.facebook.com/home.php#/pr...67&ref=profile
Mightyboss is offline
Old 08-10-2009, 05:48 PM   #754
Grendel's Avatar
It depends on how you approach this mod...
I used 20' of 1/4 fuel line, but didn't use any 1/8, used brass coupling/adapters instead. I did the "T" junction for the rear diff and locker and brought it up to engine bay as a single line, then also ran separate lines for the tranny and transfer case...for a grand total of three filters...ended up with about 8" of extra hose when done.
I know others have run the locker independent of the rear diff with 1/8 line and also used 1/8 line on the transfer case...as I said...depends on your approach.
Mightyboss previously said: View Post
Grendel is offline
Old 08-10-2009, 07:15 PM   #755
Mightyboss's Avatar
Thanks, do you know what size line is up front diff? the 2 that toyota has already done, want to replace them with breaters as well and relocate all together. 2 diff size lines it appears.
THANK YOU
Old 08-20-2009, 09:06 AM   #756
Member Number: 30223
Sorry, new here. I see a lot of folks running breathers to the inside of the engine compartment which is considerably higher than stock. However, if you have a snorkel do you not want your breathers as high as that. Possibly into the CAI? I used to wheel in AK a bit and when routing diff breathers we tried to get them as high as the air filter intake if not inside the air intake.
Thanks. Sorry for the awakening.
FNG
jdlcruiser is offline
Old 08-20-2009, 09:49 AM   #757
Grendel's Avatar
Hmm...at first glance your assertion seems reasonable. I think the one thing that I would be concerned about though is essentially having ram air and thus positive air pressure on your breather tubes.
I know that some have expressed concern about increasing positive air pressure simply by having the filters in the engine bay. Pure speculation about the air pressure on my part so I'll have to leave it to those on the forum who have a better understanding of the real world physics based on actual knowledge and experiences.
I wonder what the approach is by the fellas "down under" who use snorkels on their rigs on a regular basis. It seems like the after-market breather tube extension kits for the Rovers that I've seen available only take them into the engine bay...
...and welcome to the forum jdlcruiser.
jdlcruiser previously said: View Post
FNG
Grendel is offline
Old 08-20-2009, 10:36 AM   #758
FJ FunJunkie's Avatar
Member Number: 7470
the tranny is routed to the engine bay and the rear diff is in the jack compartment. I dont smell it if i have the windows up and have it on inside air. I've only noticed the strong smell when i step on the gas going up hill and if the window is down. Never had a problem until this mod was done. The tranny is routed right up near the vents in the engine bay is it possible that the fumes r comin through there or im smellin somethin else? could there be something wrong with the tranny if it smells like that ?
I had this problem too, found the front tcase was leaking from the center seal way in the back where it was hard to see.
In for warranty as I type
DO CLICKHow to use ADVANCED search function for Dummies
I would like things to be fun again, that is all.
FJ FunJunkie is offline
Old 08-20-2009, 10:01 PM   #759
Thank you for the welcome.
Seems to me that as little air actually passes through breathers there would not be enough suction to suck in through the seals, which I believe is the greatest concern. It is pressure and as long as the air intake is larger that the throttle body the amount that would need to come through the breathers would not be a factor. Pressure follow least resistance like electricity. Or more like filling a glass with water, the input would be the pitcher and the glass would be the diff. Once the glass is full it runs over the table not necessarily altering the water already in the glass.
I was just wondering. I did the breather mod this morning and ran the four up front to the driver side fender and the rear to the jack compartment. But I had dealt with this stuff in the past. In one of my old rigs I ran in water over the hood with no snorkel and as long as I kept forward momentum the bubble created by the hood and fender left enough air space to not take in water. Of course on that rig i worked on it enough that I typically knew what it needed on a moment by moment basis. Never got water in my diffs either. I will take lucky over good any day.
Thanks for the write up, I never would have finished mine without it.
the photo tutors were fantastic.
Be well
JLa
Old 09-10-2009, 02:28 AM   #760
NDA431FJ's Avatar
Member Number: 10370
Did the Scuba mod today. I used two red Spectre 3992 breathers (got them from Amazon @ $3.61) for the front (Transmission, Transfer Case) and rear Rear Differential & E-Locker). Amazon.com: Spectre 3992 Red and Chrome Cotton...Amazon.com: Spectre 3992 Red and Chrome Cotton...
I mounted them in the intake manifold bracket.
The T for the front;
TLCA #17592
2007 FJ Cruiser 4x4 Auto TI - Mods too long to list
2007 BMW 335i Black Sapphire - Twin Turbo
2000 Honda Odyssey EX - Navigation
1998 Toyota Sienna XLE - Supercharged (minivan with the element of surprise)
1989 Toyota Pickup - long bed
NDA431FJ is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
JAC
