Old 09-13-2007, 08:12 AM   #1 (permalink)
ruebarb's Avatar
Member Number: 1493
Post Gearing vs Tire Size Article
I found an interesting article about gearing vs tire size, figured I'd share it.
2.1mb pdf download
Once you get past the ad, you'll have a download page
ruebarb is offline
Old 09-13-2007, 08:17 AM   #2 (permalink)
Pacific Coast Moderator
uphill's Avatar
Member Number: 10461
Re: Gearing vs Tire Size Article
Maybe it's just me, but the article wouldn't come down the ether-pipe to my machine. Could you post the article here or cut/paste a synopsis?
How does the Dept. of Transportation
convince deer to cross the road where
these signs are displayed?
uphill is offline
Old 09-13-2007, 08:24 AM   #3 (permalink)
5280FJ's Avatar
Member Number: 7663
Safari can’t open the page “http://bcvrf.yahoo.com/bc/44071251mc...ire.pdf” because it can’t find the server “bcvrf.yahoo.com”.
5280FJ is offline
Old 09-13-2007, 08:50 AM   #4 (permalink)
ruebarb's Avatar
Member Number: 1493
I changed host for the file, yahoo breifcase didn't seem to work for everyone
ruebarb is offline
Old 09-13-2007, 06:31 PM   #5 (permalink)
DustPark's Avatar
Member Number: 9236
uphill previously said: View Post
I have read that article from OffroadAdventures Sept 07. It basically talks about producing a grenade in the Diffs. Stressing small axles with small pinions. It's a regearing article. 4.56 gears with a our Toyota 8 inch and 34 inch tires is a good sturdy setup. I'm confident with that setup. Bigger axles can go lower. But for the FJC 4.56 is the max, with running our current axles. We shall see and learn in the future. knock on wood. This FJC is still new.. I should be regeared in time for the meet and greet.
DustPark is offline
Old 09-13-2007, 07:59 PM   #6 (permalink)
Sean K.'s Avatar
Member Number: 9441
Alot of that information about smaller pinions is misleading. Yep, many have less teeth on the pinion....but just how many teeth do you think are actually in contact with the ring as it rotates?
Might want to read this site....it's Toyota specific.
571 gear strength
Zuk is probably one of the most knowledgeable and experienced Toyota third member gear installers in the USA.
IME, the ratio isn't as much of a problem as proper set up.
Sean
Do you need a ladder, so you can get the **** over it?
Sean K. is online now
Old 09-13-2007, 08:46 PM   #7 (permalink)
Fly Jester's Avatar
Member Number: 3323
Location: Heber Valley, Utah....or fishing on a local stream or river.
Here are a couple of links that give ratios for different applications;
Rocky Road Outfitters:
Gear Calculator
Look on the left side of the web page for calculating applications;
4LO.COM :: On-Line Gear/Tire Size Calculators
Fly Jester is offline
Old 09-14-2007, 07:45 AM   #8 (permalink)
DustPark's Avatar
Member Number: 9236
So 4.10 gears would be great with 34 inch tires.
I calculated a new ratio of 3.40:1 with 4.56 gears and 34 inch tires and a rpm of 2184 at 65 mph.
I agree the set up / install has to be great.
DustPark is offline
