Old 09-14-2007, 03:36 PM   #1 (permalink)
The Laughing Moderator
LandCruiserSteve's Avatar
Member Number: 8627
Thumbs up Silencing the noisy Hi-Lift Jack
HiLift Jacks are like over-talkative friends. Always there and helpful when you need them, but never quiet when you don't.
Amongst the many threads of the Forum are a variety of means and aftermarket devices for attaching your HiLift to your FJ. However, as secure as your HiLift will be attached to your truck, the HiLifts are still one of the most annoying and rattle-infested pieces of gear you can carry.
There are four distinct areas of the HiLift that stir up this clankity-clunk orchestra, and a fifth area that will howl with an incessant whistle . . . . second only to a San Francisco Bay fog horn.
The metal-to-metal areas need to be silenced first. And, it's easily done with a roll of electrical tape, an old credit card and a handy device called a HiLift Jack Handle Isolator (made by Daystar).
Area 1 - the jack handle.
Remove the cotter pin, slide out the handle, and then wrap about two layers of electrical tape approximately 2 inches from the end.
Slide the handle back into the HiLift and re-insert the cotter pin.
Area 2 - the HiLift jack base.
Remove the cotter pin, slide the base off of the jacking shaft, and wrap two layers of electrical tape about an inch and a half from the bottom.
Pinch the tape down to conform to the H-shaped contour of the base, slide the base back onto the HiLift and replace the cotter pin.
Area 3 - the ratchet assembly.
From the bottom end of the ratchet assembly, slide an old credit card between it and the jacking shaft. (The credit card will slide in about 1 1/4".)
Cut off any remaining exposed section of the credit card.
Upon needing the HiLift jack, this credit card "shim" will fall out instantly the first time the HiLift is ratcheted upward.
Area 4 - the bouncing jack handle.
The Daystar "Isolator" can be purchased for about $11 from most off-road supply companies. Daystar Products - Expedition Exchange Incorporated
Slide the Isolator onto the HiLift jack handle to prevent metal-to-metal contact between the handle and the jack. Of course, the Isolator will have to be removed or slid out of the way prior to using the HiLift.
Area 5 - the jack handle "wind tunnel."
If your HiLift is mounted on the outside of your FJ facing forward, and you can't seem to track down the source of that shrieking whistling sound, look no further than the open handle of your HiLift jack.
A black 1 1/4" rubber chair leg tip (available form Lowe's, Home Depot, etc.) can be slipped onto the open end of the HiLift handle to completely silence that obnoxious whistling.
Prior to sliding the rubber tip onto the jack handle, smear a little bit of liquid hand soap into the tip. This will allow the tip to be easily slid off when you need to remove your Isolator for use. And, it's not a bad idea to put the rubber tip back on the handle during HiLift usage . . . . for a little more cushioning in the event that the handle decides to introduce itself to one of your more precious body parts.
Your HiLift Jack will now be free of virtually every relentless rattle, clunking sound, creak, squeak and whistle that has been plaguing you all these years. You can now "go in peace."
Shadow-Warrior also has this "quieting" mod for the Hi-Lift: Hi-Lift Rattle MOD
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
LandCruiserSteve is offline
Old 09-14-2007, 03:40 PM   #2 (permalink)
Corey's Avatar
Member Number: 2902
Re: Silencing the noisy Hi-Lift Jack
Fantastic!
I heard my jack rattle when it was on my roof, but I hear it MORE now with it up on the ARB.
I also have WabFab's slider adaptor, so I get a little more noise.
I will look over your info Steve and try and quiet mine down.
Corey
2007 FJ Cruiser
ARB bumper, Warn XD9000, OME lift, snorked, penthouse, to much to list, see my website & buildup thread
YotaTech | My Website | My Rigs Build-Up | My Penthouse | Video Of My Penthouse | Camping Gear Reviews | Rehinging Your ARB/Engel Fridge
Corey is offline
Old 09-14-2007, 03:42 PM   #3 (permalink)
jeshua's Avatar
Member Number: 6888
Rep to you my friend! this is a great post for sure thanks a million.
Edit:
no rep for you I must spread the love.
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is offline
Old 09-14-2007, 03:45 PM   #4 (permalink)
volhoo's Avatar
Member Number: 5140
Great write up Steve.
I can't wait to try it...
Vince / volhoo
Happy Trails...
My Rig:
http://www.fjcruiserforums.com/forum...brigadier.html
My Artwork:
http://homepage.mac.com/vincepeterson/PhotoAlbum2.html
volhoo is offline
Old 09-14-2007, 03:51 PM   #5 (permalink)
RicoVerde's Avatar
Member Number: 11994
Excellent!
This has been the bane of my on-road FJ existance since the first day I mounted my highlift on the rack.
I have tried many more "Rube Goldbergesque" solutions to no avail so these simple tips are great to see.
The whole situation is exacerbated by the fact that the rack tubing acts like a speaker dumping every little rattle right over the driver and passenger's heads.
Rico's Rhino
'07 BD, AT, AllPro sliders, Hilift , fourtracks shovel mount and shovel, nuvi 660 GPS, ProClips for ipod and GPS, Cobra CB, Bandi mount, 4' firestick, EMU Heavy/Med suspension, Hella Black Magic driving lights on Defiant bar, 5 IPF lights on N-Fab roof bar, 3 pc. Allpro skids, AllPro pro links with skids, AFE CAI & TBS, BFG 285/70/17 M/T, TWM shift knobs, Wet Okole seat covers, AllPro rear bumper, AllPro high clearance exhaust, Lucrum Mount, M8000 w/synth line, gloomy bear
RicoVerde is offline
Old 09-14-2007, 04:07 PM   #6 (permalink)
JDMSi92's Avatar
Member Number: 8828
Not bad. I use zip ties, which suck to cut and reapply when done with use. I may have to give this a try!
My Location
JDMSi92 is offline
Old 09-14-2007, 04:26 PM   #7 (permalink)
4XX4's Avatar
Member Number: 9918
Dang! Another great idea, shared with instructional pics made easy.
Thanks, Steve! Reps when I can ( too recent to you).
Blacksand Beast.
El Toro Rojo
http://www.fjcruiserforums.com/forum...toro-rojo.html
FJC Club ( Creepin' n Climbin')
Aloha FJ Cruisers (Wheelin' in paradise)
SoCal FJ Cruisers tag-a-long
4XX4 is offline
Old 09-14-2007, 04:54 PM   #8 (permalink)
MudLovingFJ's Avatar
Member Number: 8945
Send a message via AIM to MudLovingFJ
thanks steve for the excellent write up again.
i already have the daystar isolator, but need to attack the jack with some e-tape as soon as i get it back.
The So-Cal Safari Snorkel Install Guy 7 chicken necks installed to date
MudLovingFJ is offline
Old 09-14-2007, 04:55 PM   #9 (permalink)
Jason242's Avatar
Member Number: 11611
Clever. Ima tape mine up ASAP. Thanks!
Stock Silver 2007 FJ 4x4 6 spd, minor mods.
FJ KIA. RIP Goliath.
Tread lightly but carry a big hi-lift.
Take it slow and stay on the trail. And always remember the FJ is HEAVY. JMHO as a reformed trail-blazer.
Jason242 is offline
Old 09-14-2007, 05:42 PM   #10 (permalink)
Archy Chris's Avatar
Member Number: 7128
I have used the Daystar Isolator on the handle, a rubber tarp cord around the Hi-Lift jack base to the roof rack and a rubber insert for the handle to cut the whistling noise down. I have been running this set-up for 6 months now with no noise coming from the Hi-Lift jack, which is mounted on the roof rack. chris
'07 Voodoo Blue/6MT/Upgrade #1 Package/Roof Rack/Towing Package/ALL-PRO Mods: Front Bumper w/Prerunner Light Bar, Rock Guards, Full Skid Plates, High Clearance Exhaust, Ultimate Lower Skids, Shock Skids/aFe Pro-Guard 7 CAI/KC Daylighters/BFG AT/KO's 285x70x17 Tires/Magnaflow Exhaust/Man-A-Fre Extended Brake Lines/Power Tank/Manik Taillight Guards & Roof Rack Light Bar/SWAY-A-WAY Coil-Over Suspension/Light Racing Adjustable UCA/Safari Snorkel, SCUBA Mods + a butt load more mods..
Archy Chris is offline
