LandCruiserSteve previously said:
Yep, that's basically it. However, you might want to do your actual trimming in incredments as to not cut off too much of the plastic.
Once you make the cuts there will be one large piece? 1. the small piece that will be left after cutting it away from the stock bumper (bolts back on near the cargo area).
2. The larger bumper piece that housed the the silver wings and runs across the entire back of the FJ. Im assuming in the pic below you will cut away the entire area where the reflector lights are? Cutting across the top and then down the sides. So the OEM bumper piece you could originally step on is gone.
Like other's have said your installation instructions look much better then the instuctions on allpro's website----
All Pro Off Road
