Old 09-15-2007, 02:07 PM   #1
The Laughing Moderator
LandCruiserSteve's Avatar
Member Number: 8627
Thumbs up All-Pro Rear Bumper Installation (pics)
All Pro Off Road
The All-Pro rear bumper, like its front bumper counterpart, is a relatively straight-forward installation. Total installation (including the removal of the rear OEM plastic bumper) was about 3 hours.
One of the most time-consuming efforts was cutting sections out of the OEM bumper's trim areas that would eventually be retained for installation for the new bumper. (By the way, with the exception of the plastic corner bumper pods, there will be no salvagable remains of your OEM plastic bumper after this installation.)
The other time-consuming task was once again trying to make sense of the installation intructions. Just like the front bumper instructions, a customer shouldn't be looking at out-of-order blurry pictures, confusing text, grammar/spelling errors and significant steps completely left out. (Note to All-Pro: Let's start providing instructions that are comparable to your fine products!!)
Anyway, here is the "nut-shell" version of the installation:
First, disconnect the back-up sensors on both sides of the inner rear bumper. Remove the plastic OEM bumper by taking out the five upper screws and the four lower bolts. The edges of the plastic bumper snap off of both sides. The rear tow hook will have to be removed prior to installation. And, if you have the OEM trailer hitch installed, it will also have to be removed.
At this time, you can also remove the actual back-up sensors from the OEM bumper. They're retained by slide clips, and don't forget to re-install them into the All-Pro bumper prior to installation.
Remove the corner bumper pods by sliding out the inner retaining clips.
Using a small hand saw or a handheld electric jig-saw, create a "window" in the inner sections of where the corner pods where previously mounted.
With a straight-edge, draw a cut line across the top of the OEM bumper trim panel. And, cut the entire width of the trim panel away, leaving about 3 1/2 inches. The new bumper will eventually overlap this remaining trim piece.
Re-install what remains of the OEM bumper's upper trim panel and the corner side trim pieces. (This should be one long piece, including the wrap-around corner sections.) Snap the corner side trim pieces back into place.
Slide the All-Pro bumper onto the rear cross-member and use the accompanying hardware for attachment. Prior to final tightening of the bolts, ensure that the bumper sits level with even gaps on both sides.
After final tightening of the mounting bolts and trimming a few other portions of the original remaining plastic trim pieces, your All-Pro rear bumper will be installed.
By the way, the factory departure angle on a stock (no lift/stock tires) FJ Cruiser is 30 degrees. With BFG 285's and an OME lift kit, my departure angle with the OEM bumper was about 33-34 degrees. The All-Pro rear bumper substantially increased my departure angle to 44 degrees.
Now my rear end matches my front.
I ask you . . . . what more could I possibly ask out of life??
Steve
The '07 Kiroi Hako
'78 FJ40
TLCA #6727
UFWDA
LandCruiserSteve is offline
Old 09-15-2007, 02:11 PM   #2
FJ #8's Avatar
Member Number: 121
Re: All-Pro Rear Bumper Installation (pics)
looks badass...... I would get it if i wasnt waiting for the demello
FJ #8 is offline
Old 09-15-2007, 02:15 PM   #3
Super Moderator
Shadow-Warrior's Avatar
Member Number: 3913
Steve, as always a great how too thread by you. I'm gald to see you finally got your rear bumper, it looks like it was worth the wait. Your rig looks awesome buddy. Great job
TLCA Member : #18084
Honorary AZFJ Club Member
Honorary SoCal Club Member
FJ Cruiser Club Member
Meet The RAPTOR 2007 TRD SE
Shadow-Warrior is offline
Old 09-15-2007, 02:16 PM   #4
TCao's Avatar
Member Number: 940
Thanks again for another well-written tech article. I hope All Pro will give you a huge discount on your next order.
2007 Ti FJC
TCao is offline
Old 09-15-2007, 03:57 PM   #5
MudLovingFJ's Avatar
Member Number: 8945
Send a message via AIM to MudLovingFJ
steve, what are you trying to do here? you have given us so many helpful threads in the past few days that you are making my head spin!
thanks once again for an excellent write up, you are the man!
Do it right the first time or don't do it at all.
ICONs/35s/Demello
The So-Cal Safari Snorkel Install Guy 11 chicken necks installed to date
STAY TOGETHER YOU HUMPTY-DUMPTY OF A TRUCK!
MudLovingFJ is offline
Old 09-15-2007, 04:48 PM   #6
Member Number: 4584
Send a message via AIM to yusuke41
you can ask for black side mirror and door handles... other than that NICE!!!
yusuke41 is offline
Old 09-15-2007, 06:56 PM   #7
Gottagetone's Avatar
Member Number: 12336
Nice!
Why not ask for a supercharger?
“Since you have chosen to elect a man with a timber toe to succeed me, you may all go to hell and I will go to Texas.”
Davy Crocket
My Rig:
Gottagetone is offline
Old 09-15-2007, 07:06 PM   #8
Member Number: 7877
Very nice write-up. Your rig is starting to look like an assault vehicle.
kirkster70 is offline
Old 09-15-2007, 09:03 PM   #9
FJ Expeditions R Us
w5wi's Avatar
Member Number: 11734
[quote=LandCruiserSteve;
[/QUOTE]
Hmmm, That is not quite the profile I recall
Now, for the real reason I posted! Great install! Can the OEM trailer hitch be mounted below the bumper?????
thanks
dale
Happy Trails!
TLCA #17625
LOS TRES AMIGOS IN MEXICO
TITANIUM METALLIC--A/T
ARB Bumper - Warn Winch - OME Heavy 886/895 - Bandi Mount - All-Pro Lower link skids - Bud Built skids - Snorkle - Toyota prefilter (cyclone air filter) - Optima Yellow Top Battery - Painless Dual Battery Control System - Scuba Driver Mod - Kenwood DNX 7120 GPS - A-TRAC mod - 110v add-on - Rock Rails - Rear Locker - Roof Rack - BFG TA/KO's - ARB Fridge/Freezer - '08 side visor mod - Royal Purple fluids - E3.68 Spark Plugs - All Pro Rear Bumper - All Pro Lower Links - M-Pac rear and side mounts - AT Cooler
To be continued...
w5wi is offline
Old 09-15-2007, 10:00 PM   #10
Member Number: 6748
I definitely think that is one of the best looking rear bumpers. It also looks like All Pro may have updated the design. I looks like there are no more self tapping screws required?
Thanks,
Shawn
Briareos is offline
