Old 09-20-2007, 01:49 PM   #1 (permalink)
Jo2
Jo2's Avatar
Member Number: 615
Jacking up the FJ....
Well it occured to me that after lifting with the OME kit and throwing 33" tires on I probably need to invest in a good jack.
-Is a Hi-Lift the way to go?
-Is it customary to keep this on your car at all times?
-If so, where do you mount it, or store it if you don't have a roof rack?
Jo2 is offline
Old 09-20-2007, 02:07 PM   #2 (permalink)
1 Bored Clerk's Avatar
Member Number: 741
Re: Jacking up the FJ....
A hi-lift is a must off-road, but I wouldn't drag it around all the time. Check your factory bottle jack...it may have enough travel to still work (sorta doubt it, but you could check) If you need to haul around a Hi-Lift, there are several members that have mounted them just in front of the back seats near the floor. There are other options too...I'm sure you'll get posts pointing to those.
1 Bored Clerk
Inchworm Gear E-Locker Guard
1 Bored Clerk is offline
Old 09-20-2007, 02:18 PM   #3 (permalink)
Admudistrator
Dragon's Avatar
Member Number: 2479
that mount is made by FourTreks FOURTREKS HOME
"Monzen no kozo narawanu kyo o yomu."
Experience is the best teacher
Taira
Click
Dragon is online now
Old 09-20-2007, 02:29 PM   #4 (permalink)
Jo2
Jo2's Avatar
Member Number: 615
should a high lift *only* be used for offroad whereas a jack + some wood underneath it is better suited for driveway wrenching?
Jo2 is offline
Old 09-20-2007, 02:34 PM   #5 (permalink)
jeshua's Avatar
Member Number: 6888
Jo2 previously said: View Post
in the driveway you want to use jack stands. How you get the jack stand under there is up to you. but a jack if a better/safer then a hi-lift.
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is offline
Old 09-20-2007, 03:40 PM   #6 (permalink)
homedad's Avatar
Member Number: 10257
The problem with the hi-lift....there are no lift points on the truck unless you have aftermarket bumpers or sliders.....but I wouldn't wheel without one....
homedad is offline
Old 09-20-2007, 03:46 PM   #7 (permalink)
Jo2
Jo2's Avatar
Member Number: 615
homedad previously said: View Post
stock sliders gonna work?
Jo2 is offline
Old 09-20-2007, 03:55 PM   #8 (permalink)
homedad's Avatar
yes but there's an adaptor that goes on the jack to grab the rails
from Wabfab
homedad is offline
Old 09-20-2007, 05:03 PM   #9 (permalink)
Member Number: 741
If you are talking only about jacking up the rig in the driveway to wrench on, get yourself a floorjack and some jackstands. You will have them FOREVER and, if you like to wrench, you will use the hell out of them. It's money well spent...if you consider the cost over how long they last, they are practically free. I'm still using the floor jack that my dad was using in the 70's...same jackstands too. You don't need some gigabuck racing jack...just something nice and solid.
1 Bored Clerk
Old 09-20-2007, 05:31 PM   #10 (permalink)
TSR
TSR's Avatar
Member Number: 7752
Anyone using the ARB Bushranger X-Jack ?
Bushranger X-Jack - Expedition Portal Forums
2007 TRD - 3" OME lift - 17" M/T Classic Locks - 33x12.5 M/T MTZ's
"Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties."
Abraham Lincoln
TSR is offline
