Old 05-02-2006, 05:46 PM   #1 (permalink)
cville's Avatar
Member Number: 1557
Mount for high-lift jack on rack?
Is their a Mount for a high-lift jack that will fit on the stock rack?
cville is offline
Old 05-02-2006, 06:03 PM   #2 (permalink)
Perv3rse's Avatar
Member Number: 814
Send a message via Yahoo to Perv3rse
Re: Mount for high-lift jack on rack?
I found this accidentally. I think it might be what youre looking for.
www.sor.com
Perv3rse is offline
Old 05-02-2006, 06:59 PM   #3 (permalink)
Tacoma_Tom's Avatar
Member Number: 1080
The 4xrac is what I'm planning on using. I'm going to bolt it to some flat plates on the opposite side of the roof rack. That way it clamps down tight around the rack. I'm just a little nervous about wind noise.
Tacoma_Tom is offline
Old 05-03-2006, 07:03 PM   #4 (permalink)
Toyotaman's Avatar
Member Number: 228
I have been working on this problem for a couple of days. I think I am going to attach it to the fron bumper. There is a steel frame that runs the length of the lower half and I think it would look mean mounted there...at least that will be temporary until I have the ARB put on next year.
I looked at the mounts pictured above and they seem like they will stick out too far from the roof rack. I think if I decide to mount it up there (still a possibility) I will use U-bolts and a steel plate to secure it within an inch or so of the rack.
Toyotaman is offline
Old 05-03-2006, 08:23 PM   #5 (permalink)
highbeams's Avatar
Member Number: 1769
nevermind
Full of life and loving it.
Save the cactus
highbeams is offline
Old 05-15-2006, 11:15 PM   #6 (permalink)
tisilverFJ's Avatar
Member Number: 1394
Already had the Yakima Hi-Lift mount that is made for the load warrior basket. I had my local offroad shop mod it to work with the stock rack.
mount-high-lift-jack-rack-dsc01717.jpg  mount-high-lift-jack-rack-dsc01719.jpg
tisilverFJ is offline
Old 05-18-2006, 01:47 PM   #7 (permalink)
Moderator with no FJ
4RnrJ's Avatar
Member Number: 2492
If you are looking for something to fit on the rack and not basket.. then check here:
http://sleeoffroad.com/products/prod...erior_main.htm
Just buy that hi-lift mount and then go and find a yakima mighty mount that fits the FJ. For the 03+ 4runners it was a mighty mount 10V.
Mine works like a champ!!
4RnrJ is offline
Old 05-18-2006, 11:15 PM   #8 (permalink)
tisilverFJ's Avatar
Member Number: 1394
Sorry, I should have said that I already "OWN" the Yakima Hi-Lift MOUNT. It was $70 so I couldn't just throw it away. Those pictures are of it modified to fit MY FJ rack and it installed. Can't have the Hi-Lift taking up room inside of the rack. Need all the room for camping gear.
Hi-Lift jack on rack with Yakima mount.
Old 05-18-2006, 11:20 PM   #9 (permalink)
Vansmack's Avatar
Member Number: 2139
Can you post a close up view of how the Hi-Lift attaches to that braket please?
Vansmack is offline
Old 05-25-2006, 01:29 AM   #10 (permalink)
tisilverFJ's Avatar
Member Number: 1394
Vansmack,
Some pics for you. The bracket mounts with 4 bolts. Two of them are also used for the HI-Lift. Very solid and I don't need to lock it.
mount-high-lift-jack-rack-dsc01778.jpg  mount-high-lift-jack-rack-dsc01779.jpg
