Old 09-25-2007, 03:24 AM   #1 (permalink)
Decidion's Avatar
Member Number: 13809
Regular steel bolts for rails?
I had to go out and buy bolts for the rails I picked up second hand, and I just bought regular steel. But then I got to thinking...should I have bought hardened steel or stainless steel? Or some other higher strength steel?
Decidion (Jeff)
'08 Brick Red
Too many mods to list...
Decidion is offline
Old 09-25-2007, 03:49 AM   #2 (permalink)
Banned
Member Number: 11622
Send a message via AIM to SavageX25
Re: Regular steel bolts for rails?
Stainless should be fine.
SavageX25 is offline
Old 09-25-2007, 06:08 AM   #3 (permalink)
NCFJ's Avatar
Member Number: 8585
I'd go with grade 8 bolts myself
NCFJ is online now
Old 09-25-2007, 07:50 AM   #4 (permalink)
Kansas Law Dog's Avatar
Member Number: 931
The bolt size is 8mm (M8), which has a head size that takes a 13mm wrench. I recommend 1-1/2" long (35-38 mm), with flat washer and locking washer. For strength I recommend bolts with 10.9 stamped on the head, as these are rated for the equivalent of 120K psi; whereas standard bolts are typically 60K psi. When installing the bolts tighten to 22 foot-pounds of torque.
Kansas Law Dog is offline
Old 09-25-2007, 08:02 AM   #5 (permalink)
gascolator's Avatar
Member Number: 4247
If you use regular steel, use lotsa Nevr-Sieze to ensure that they don't rust
solidly into place. Lock-washers of course to keep 'em tight.
Any advertisements embedded in the text of this posting are placed by the hosting service, and as such do not represent the author's endorsement of the named product or service.
gascolator is offline
Old 09-25-2007, 07:34 PM   #6 (permalink)
Mustang's Avatar
Member Number: 6616
Thumbs up Re: Regular steel bolts for rails?
Kansas Law Dog previously said: View Post
Yes. And the ones with the yellow finish normally have a higher level of corrosion resistance. These are surprisingly hard to find. Like any type of metal, there are a lot of types of stainless so if you go that way, make sure you know what you are getting.
Mustang is offline
Old 09-25-2007, 07:38 PM   #7 (permalink)
Member Number: 4163
Decidion previously said: View Post
This what I did. I bought stainless steel bolts. Much easier to use. I also bought neoprene washers to seal out water. Used that under the footings of the rack. It has been a year I installed it. No problem whatsoever.
DFrelich is offline
Old 09-25-2007, 08:13 PM   #8 (permalink)
mikey's Avatar
Member Number: 2806
Even the yellow zinc plated will rust/seize, like gascolator mentioned using some Koper-Kote or similar will prevent seizing. One thing to remember about Koper-Kote is a little dab'll do you, this stuff gets everywhere and can be messy.
mikey is offline
Old 09-26-2007, 03:06 AM   #9 (permalink)
Decidion's Avatar
Thanks for all the great replies
Decidion (Jeff)
'08 Brick Red
Decidion is offline
