Old 10-04-2007, 06:08 PM   #1 (permalink)
Runt's Avatar
Member Number: 10685
Off Road light wiring
Hi FJers
Just got all my new bumper, winch, lights, switches and dual battery kit etc. together for my latest mod. For those that have wired up bumper lights, rack lights etc. what fuse type set up did you use and why (i.e. to aux. fuse box or individual inline fuses) any tips appreciated. I have been leaning towards the ease of going with inline fuses instead of one central aux. fuse panel. Now I'm having second thoughts. What are the major advantages of a aux fuse panel if all I ever plan on adding is these lights only. Seems like alot of work unless you have plans to add future electrical mods. Wiring job I'm going forward with is foglights, driving lights, factory rack lights and back up lights. I will be adding a aux. battery via Cruiser Larrys dual battery kit and light labeled switches from 4X4mods.com. I plan on mounting the switches in the bottom row of the aux. panel below the stero.
Runt is offline
Old 10-04-2007, 07:22 PM   #2 (permalink)
gon2srf's Avatar
Member Number: 6131
Re: Off Road light wiring
Runt previously said: View Post
Hi FJers
If possible, install your dual battery system first or make all your wires long enough to reach the future position of the secondary battery if your going with in line fuses. Otherwise you will be running all your lights off your primary battery and you don't want that, nor do you want to go back and rewire everything. A ground bus bar may help with an orderly installation.
The advantage of an auxillary fuse box is the placement of all those new hot and ground wires. Just one 4 gauge hot/ground wire from the aux. battery to the aux. fuse box your set. Run all the lights to it. Wire all your switches to a key on fuse or directly to your aux. fuse box if you want full time power. Running all those light through the roof is my advice however others with tell you to go the pillar route.
Gon2srf
TLCA#16768
33' BFG MUD's, Icon Front Coil Overs, OME Rear Shocks and Coils. ARB Bumper, Warn 9500XD winch, MAF Sliders & Skid Plates, Gobi Ranger Rack w/ PIAA Lights ft, rr, sd, w/Gobi Hi Lift, axe and shovel Mounts, dust lights. Dirty Parts Dual Battery System, Cobra 75 WX ST CB, Extreme Hi Lift Jack, Power Tank 10 lbs. CO2 System, All Pro HD LCA's, Custom Rear Drawers. Custom electrical.
Emerald Pacific Financial
949 235-1494
gon2srf is offline
Old 10-04-2007, 07:25 PM   #3 (permalink)
gon2srf's Avatar
Member Number: 6131
If possible, install your dual battery system first or make all your wires long enough to reach the future position of the secondary battery if your going with in line fuses. Otherwise you will be running all your lights off your primary battery and you don't want that, nor do you want to go back and rewire everything. A ground bus bar may help with an orderly installation. Run direct ground wires to the chassis/batt groun or ground bus bar from your lights. Don't use the roof rack grounds if at all possible.
The advantage of an auxiliary fuse box is the placement of all those new hot and ground wires. Just one 4 gauge hot/ground wire from the aux. battery to the aux. fuse box your set. Run all the lights to it. Wire all your switches to a key on fuse or directly to your aux. fuse box if you want full time power. Running all those light through the roof is my advice however others with tell you to go the pillar route.
Gon2srf
TLCA#16768
949 235-1494
gon2srf is offline
Old 10-04-2007, 08:05 PM   #4 (permalink)
Runt's Avatar
What are you getting at when you refer to "pilliar route" to "running through roof". I was planning on doing a bit of both i.e. taking apart the rack snaking all the wires through there, then drilling a hole under the foot of the front rack and down through the pillar. Is there a another way?
Runt is offline
Old 10-05-2007, 11:15 AM   #5 (permalink)
gon2srf's Avatar
Member Number: 6131
Yes. The outer cover on the pillar is removable. Many folks remove the cover and run the wires this way. IMO there is not enough room to run the proper gauge and number of wires for a decent install.
Do some searching and you'll find all the threads on this topic.
TLCA#16768
949 235-1494
gon2srf is offline
Old 10-05-2007, 11:17 AM   #6 (permalink)
jeshua's Avatar
Member Number: 6888
gon2srf previously said: View Post
Yep my A-pillar looks like crap cause of that. I would like to go through the roof but I am to lazy and don't have the time right know ether.
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is online now
Old 10-05-2007, 08:41 PM   #7 (permalink)
gon2srf's Avatar
Member Number: 6131
I'd be glad to help you when you find time! I've done it twice now so I'm getting faster.
TLCA#16768
949 235-1494
gon2srf is offline
Old 10-05-2007, 09:01 PM   #8 (permalink)
thugasaur's Avatar
Member Number: 691
Send a message via AIM to thugasaur Send a message via Yahoo to thugasaur
ok so i got a dumb question is it possible to tie 4 roof lights into one wire and connect it to the aux battery saving space in the pillar i have issues with drilling a hole in my roof
Chefj's Little known facts: Thugasaur tracked down, strangled, and gutted the Snuggle fabric softener bear because he once had a towel that was...well...not so soft.
UBFM member #00 enforcer
"Church" V2.0
2007 Voodoo 5AT 4x4
______________________
AFE cai , kenwood excelon 889 , xm2go, piaa extreme super whites , demello front skid plate and rock rails and aero flow lens covers (THANKS GUYS!) , all-pro front sway bar links
thugasaur is online now
Old 10-05-2007, 09:45 PM   #9 (permalink)
felonious's Avatar
Member Number: 12866
the gage of wire that you would have to run would be to heavy to fit down the a pillar on the outside. So the only route would be through the roof its not that bad to do if you take your time.
felonious is offline
Old 10-07-2007, 11:26 PM   #10 (permalink)
gon2srf's Avatar
Member Number: 6131
felonious previously said: View Post
If you drilled through the roof, which I have. You would then have room for the proper gauge wire for each light.
TLCA#16768
949 235-1494
gon2srf is offline
