Old 10-04-2007, 10:11 PM   #1 (permalink)
FJoel's Avatar
Member Number: 4197
Question Synthetic winch line questions (and hopefully answers)
Some more FJoel newbie style questions here. Be warned.
I want to go to synthetic winch line for my M8000.
Where can I buy it? Does it come in black?
I need to make myself some Delrin rollers for my Roller fairlead then, right?
I wrecked my standard cable by winching off a tree when I was stuck bad.
Is this where I should have employed a snatch block? I need to buy one.
When I get my snatch block, and synthetic cable:
Should I make myself a Delrin pulley for the snatch block as well? Is it easily disassembled?
Thank you all in advance, I'll be sure to hand out rep.
Joel
FJoel is offline
Old 10-04-2007, 10:49 PM   #2 (permalink)
SonicFJ's Avatar
Member Number: 6368
Re: Synthetic winch line questions (and hopefully answers)
I got mine with my winch so I offer no help with purchase.
Your tree incident could have went better with a "tree saver" or a short strap to go around the tree and hook the cable end to. Using a snatch block is useful for off angle pulls or when doubling the needed pull strength is necessary (go through the block and come all the way back to the vehicle with the winch). It does tend to put some nasty memory curls in your steel cables. I have used my Warn snatch block with my synthetic line, and it looks fine. As for the fairlead, I use a smooth aluminum fairlead with no rollers. The synthetic would pinch into the edges of the rollers at off angles.
You also want to carry some burlap or a towel to use as an extra chafing protection when winching over rocks or logs.
Good luck with your persuit, I am sure you will like synthetic better once you learn how to care for it.
SonicFJ
SonicFJ is offline
Old 10-04-2007, 10:51 PM   #3 (permalink)
Audiox's Avatar
Member Number: 2088
I ordered today from winchline.com. It comes in many colors including black. They were great helping me chose the right type of line as well as the accessories to go with it.
Audiox is offline
Old 10-04-2007, 10:53 PM   #4 (permalink)
ssc
ssc's Avatar
Member Number: 12618
Winchline.com treated me good. Take a look at their website.
Regards, SSC
2007 Blue Mamba, All-Pro Fox suspension all the way around, All-Pro sliders, skids, front and rear bumpers. Warn 9.5xp winch. 285-70-17 BFG-KM-2's. and a Puddy cat
ssc is offline
Old 10-04-2007, 11:25 PM   #5 (permalink)
FJoel's Avatar
Member Number: 4197
Perfect. Thanks guys.
FJoel is offline
Old 10-05-2007, 12:19 AM   #6 (permalink)
FJoel's Avatar
Member Number: 4197
Found this on their website: Installing A New Synthetic Winchline - YotaTech Forums
Nice write-up Corey Tando!
Thanks!
FJoel is offline
Old 10-05-2007, 01:46 AM   #7 (permalink)
FJ FunJunkie's Avatar
Member Number: 7470
best thing about synth is it holds no kinetic energy, if it snaps, it will drop after a couple feet with no danger, also it floats for those who like water. Definitley go with a hawse fairlead vice the roller, and yes carry some shop towels for guard on rocks and trees. I Thank Kajo for my schooling on synth...
Ligten up, it's the internet.
You Should http://www.helpchriswalk.org/
FJ FunJunkie is online now
Old 10-05-2007, 04:41 AM   #8 (permalink)
Corey's Avatar
Member Number: 2902
FJoel previously said: View Post
Thanks!
Thanks Joel.
I really like the line I bought from Winchline.
I also prefer the safety thimble over the hook I use to run.
The thimble and use of a shackle is nicer IMO.
Corey
2007 FJ Cruiser
ARB bumper, Warn XD9000, OME lift, snorked, penthouse, so much more, see my website & buildup thread
YotaTech | My Website | My Rigs Build-Up | My Penthouse | Video Of My Penthouse
Corey is offline
Old 10-05-2007, 04:56 AM   #9 (permalink)
Pacific Coast Moderator
uphill's Avatar
Member Number: 10461
Thanks!
I used Corey Tando's instructions for the install myself. You can buy the delrin rollers from Winchline.com unless you prefer to make your own. I also have had the safety thimball for some time now and prefer it over a hook for all the right reasons. I use an old wet quilt for the winchline but burlap or anything that will hold the water and impart weight helps. This is more necessary when using a steel cable that holds the kinetic energy, but never a bad idea under any circumstances.
Use a NEW snatchblock if you've run cable through the one you have (instead of synthetic line) otherwise, you don't need a delrin pully - IMO. Sometimes the snatchblock is useful, sometimes just a PULL PAL laid out in the direction of pull if there are no trees and the terrain is suitable is VERY USEFUL.
uphill is offline
Old 10-05-2007, 06:28 AM   #10 (permalink)
Sean K.'s Avatar
Member Number: 9441
Joel
How did you ruin steel cable pulling off a tree?
Sean
Do you need a ladder, so you can get the **** over it?
Sean K. is online now
