Old 10-07-2007, 09:34 PM   #1 (permalink)
L8Apex's Avatar
Member Number: 2080
My BudBuilt skids installed, PICS
When I'm on the trail I'm paranoid of ripping mechanical parts out of the bottom of my truck on rocks, tree stumps, etc. Of course I drive a careful line. But sometimes it's necessary to drag the belly of the truck over some unfriendly terrain. So I finally purchased a set of BudBuilt skids for peace of mind. Here's my story:
My FJ originally came with the accessory "bling plate". While it doesn't stand up to much, it does prevent the engine skid from taking a beating. Here's how it looked after a few trail runs:
After a lot of research on this forum, I opted for BudBuilt's 4-piece set of skids (front, mid, transfer case, crossmember.) Besides being excellent quality (as I'm sure the competitors are as well), I like the completely flat surface they provide (even though they sacrifice some clearance.) The recessed hardware also helps. And the front skid is wide to protect the alignment points. Other features and discussion can be found in the skid comparison thread.
Bud is a great guy to deal with. He takes the time to answer questions and discuss the features of his products. He's happy to provide advice on installation. And he makes sure the customer is happy. His shipping prices are reasonable for pieces of this size and weight, and delivery is fast.
Quality of the skids: top notch. These things are beefy. And everything fits correctly, with all holes in the right places, lining up perfectly. One suggestion: before installing make sure all hardware is there, including the spacer plates for the TC skid. Sometimes Bud leaves something out, sometimes parts fall out of the box as the FedEx guy drags it up the driveway. If you happen to be missing anything, Bud will send it out right away at no charge. He'll also email the install instructions, which make this an easy install.
Enough text. I'll let the pics show the rest.
Skids hanging in basement, ready to paint:
I hung them like this so I could paint both sides at once. I used Rustoleum Safety Red in a rattle can (preceded by primer). Here's the result:
I think these look great on my living room floor. Top side:
Bottom:
I pulled the truck onto ramps, and it was easy to slide underneath to install the skids myself.
To position the skids, I slid under the truck on a creeper with the skid on my stomach, then lifted it into place with my hands and knees. I also used a floor jack with a towel on the pad to support one end while positioning the other. I ran into no issues.
After the install I posed the truck for some more shots. Now the sensitive bits are all protected:
One note about the finished product: Clearance is tight at the exhaust crossover. I trimmed about 3/4" off the driver side spacer plate because it looked like it might touch with any flex at all. And now that everything is bolted up there's maybe 3/8" clearance max between the exhaust and the skid. I can't fit my pinky finger in between there:
But there's no contact and no rattles. So it's all good.
I can't wait to get out on the trail and scuff these up. I've heard that a good driver knows how to negotiate the terrain to avoid scraping the skids. But I'm still learning and pushing the limits. So I'm sure I'll be touching up the red paint a lot.
Thanks to Bud for an excellent product, and to the forum members that provided feedback on skids in general to point me in the right direction.
The Tank (aka "RED PILL") : 2007 FJ Cruiser, 4x4AT, black cherry
- Expedition One bullbar bumper
- Expedition One rock sliders
- BudBuilt skids (front, mid, TC, crossmember)
- Bilstein 5100 front struts, set at 1.75" lift
- GoodYear Wrangler Silent Armor tires 275/70/R17
The Fighter Jet: 2001 MR2 Spyder, silver
- 2ZZ motor/6spd swap
- TRD Sportivo suspension
- 3.0 Racing chassis bracing
- JDM Toyota hardtop, soft-top delete
L8Apex is offline
Old 10-07-2007, 09:43 PM   #2 (permalink)
podex_equus's Avatar
Member Number: 12815
Re: My BudBuilt skids installed, PICS
Is that paint going to burn under the exhaust?
Now go tear 'em up!
-Mike
'07 Voodoo Blue
podex_equus is offline
Old 10-07-2007, 09:46 PM   #3 (permalink)
FJammin's Avatar
Member Number: 878
Nice. How do you change the oil?
'07 Ti, Up2, Rails, Half-Rack, Toytech 3" lift, BFG AT 285's, Infinity Reference speakers, Heated seat, remote starter, Atrac+locker hack. TRD CAI. Black A-pillars, Metaltech front bumper, Superwinch epi9000, white "cap" instead of just roof.
FJammin is offline
Old 10-07-2007, 09:55 PM   #4 (permalink)
L8Apex's Avatar
Member Number: 2080
FJammin previously said: View Post
There's a 2" hole exactly under the drain plug.
L8Apex is offline
Old 10-07-2007, 10:06 PM   #5 (permalink)
Cannysage's Avatar
Member Number: 7247
the red is pretty cool, but the paint will melt off.. you need to 'powercoat' things like that..
Cannysage is offline
Old 10-07-2007, 10:21 PM   #6 (permalink)
Cred's Avatar
Member Number: 3968
The paint looks great! Love those skids look beefyand strong. I hope you are going to make it to the Cliffs on the 20th. I would love to see them up close.
TLCA # 18365
Cred is offline
Old 10-07-2007, 10:55 PM   #7 (permalink)
speedy's Avatar
Member Number: 3087
They are nice. I installed mine yesterday with some help. I have two questions.
1. Was there anything to bolt on the two holes on either side of the drain plug? I didn't bolt anything but when looking at the SKID it looks like it is suppose to. Two other Fjs didn't have any bolt either.
2. On either side of the OEM cross member where you removed the two bolts, did you put some kind of spacer to make it a flush surface? The OEM brace has a Fork indentation so to speak. So the edges now sit on the skid and the whole stress point is on this particular point. I am thinking about going back and filling the void with spacers to make it a flat surface. Otherwise the edged will only get bent in. I am referring to step 3 of removal of stock skidplates.
Thanks,
speedy is offline
Old 10-07-2007, 11:13 PM   #8 (permalink)
fj4x4's Avatar
Member Number: 13646
Nice!
Completely off the topic, I noticed you have Silent Armors (275's?). I just got these on my Black Cherry last Friday and love them..........How do you like them?
fj4x4 is offline
Old 10-07-2007, 11:20 PM   #9 (permalink)
felonious's Avatar
Member Number: 12866
I just installed the bud built skids and was thinking the same thing about doing a oil change on the engine and the first one will be a little messy but the second wont be bad after I install the sure drain fitting and there is plenty of room between the skid plates and the plug/fitting.
[IMG][/IMG]
felonious is offline
Old 10-07-2007, 11:25 PM   #10 (permalink)
speedy's Avatar
Member Number: 3087
Sure drain Filling? Please PM me more info...
speedy is offline
