Old 07-16-2006, 07:11 PM   #101
Member Number: 2730
Re: A-Trac switch install with pics
THANKS. i DID THE A TRACK INSTALL TODAY. iT WAS EASY AND IT WORKS.....THANKS FOR ALL YOU GUYS DID TO SET THESE EASY INSTRUCITONS.....yeehaw!!
ricrhino is offline
Old 07-17-2006, 04:14 PM   #102
CO-Jeff's Avatar
Member Number: 1863
Send a message via AIM to CO-Jeff
Ok, Installed my switch many weeks ago, had turned it on once and light came on and figured all was fine.
Was on the FJ Team trip to Red Cone Yesterday, no joy.... I checked to make sure the wiring had not came loose.
Any other sugguestions otherwise will have the dealer look at it.
CO-Jeff is offline
Old 07-17-2006, 04:41 PM   #103
Member Number: 2730
thanks and kudos to all yall who did the research and experimentation. I installed the switch last weekend and it was simple and fast!! Works!!!
ricrhino is offline
Old 07-17-2006, 07:21 PM   #104
other1's Avatar
Member Number: 266
Is there any chance you didn't encounter a situation that would activate the system???
other1 is offline
Old 07-17-2006, 08:02 PM   #105
CO-Jeff's Avatar
Member Number: 1863
The light came on the first time I tested it, and when I attempted again no light, the light comes on if I am correct once it is pushed.
CO-Jeff is offline
Old 07-17-2006, 08:26 PM   #106
MikeTMC's Avatar
Member Number: 3044
You probably have already checked this- but make sure the RR Diff Lock button isn't depressed and disabling the A-Trac switch.
Pic of diff lock dash light:
-Mike
2007 FJ Cruiser Voodoo Blue 4X4 5AT
AL, CQ, DL, M5, DH, LR
(The Blue Ox)
Build Date: 04/06 VIN: 00170xx Purchased: 05/27/06
Upgrades:
05/27/06- Blind spot mirrors & wheel locks
06/20/06-Toyota secondary Hi-pitched horn #86510-60240
06/28/06-NAPA Balkamp locking gas cap #703-1641
07/06/06-Toyota A-Trac Switch #84988-35060
07/06/06-Toyota Subwoofer Switch #86171-35010
07/16/06-Toyota "Predator" step bars (N-fab) #00012-M0773-01
08/02/06 Stock Steel Wheels
08/07/06 "Bandi Mount"!
MikeTMC is offline
Old 07-17-2006, 09:05 PM   #107
CO-Jeff's Avatar
Member Number: 1863
yep, done that.
CO-Jeff is offline
Old 07-18-2006, 11:09 AM   #108
trdsource's Avatar
Member Number: 752
yep, done that.
Did you buy the switch from us?
trdsource is offline
Old 07-18-2006, 11:17 AM   #109
Wolfbak's Avatar
Member Number: 1119
yep, done that.
There are 3 things that must be done in order to get the light (and A-Trac) on.
1. Push the A-Trac button
2. Make sure the rear diff button is NOT pushed
3. Shift into 4Lo
If all this is done and it doesn't work, then it may be worth checking the switch. I'm not sure I would go to the dealer to get a "hack" fixed.
Wolfbak is offline
Old 07-19-2006, 06:13 PM   #110
PRCruiser's Avatar
Member Number: 3524
Send a message via MSN to PRCruiser
As I noticed with the test, I installed the a-trac switch and nothing happened. So its true that you have to have th RR DIFF LOCK button to do the hack thing. I feel shamed...
I also bought the diff lock button just to fill the blank button covers and to light up at night.
To all guys overthere who could make the atrac to work: ENJOY THE PACKAGE SAVING!!!! while I keep throwing things to the floor.
PRCruiser is offline
