Old 11-02-2007, 01:34 AM   #1 (permalink)
FJ-Ollie's Avatar
Member Number: 6685
O&B Fab Front Swaybar Collar Mod
This idea isn't totally mine. I'm almost POSITIVE that the swaybar link failure issue is due to swaybar shift from factory collars coming loose. Dustpark ordered some collars to replace the cheap ones on the swaybar. I took some measurements and decided to have my machinist make some super beefy collars. The swaybar diameter at the collar point measures between 1.135" and 1.165". I drew up a sketch of a collar for my machinist and this is what he spit out for me in about 3 hours. He made them out of solid steel bar stock. He cut four of them for me. I'll be beta testing a set and so will Frogeye.
ID=1.150" OD=2.500" Thickness=1.00" The cap bolts are 5/16" Grade
The crappy aluminum collars I cut off. (With a jab saw mind you.)
Passenger Side
Driver Side
"OLLIE" (AKA: FU-OLLIE)
K6JYB / "Head Butcher"
Check Out "OLLIE's" FJ:
FJ-Ollie is online now
Old 11-02-2007, 03:38 AM   #2 (permalink)
Audiox's Avatar
Member Number: 2088
Re: O&B Fab Front Swaybar Collar Mod
I need a set of those. I noticed that my passenger side was floating around on the bar.
Audiox is offline
Old 11-02-2007, 11:06 AM   #3 (permalink)
frogeye's Avatar
Member Number: 6849
Thumbs up Re: O&B Fab Front Swaybar Collar Mod
Oh man it's great having Ollie as a friend . Killer parts. I hope to be reporting no more sway bar shifting soon! We are going to Calico this weekend so we might have a chance to test them out.
Chris | My FJ El Froggo
www.frogeyesprite.org
Save The Cactus!!!
NObama!
Drill Baby Drill
frogeye is offline
Old 11-02-2007, 11:09 AM   #4 (permalink)
jeshua's Avatar
Member Number: 6888
They look awesome Ollie, You and your friend do it again.
Good luck this weekend guys, I hope you find that girl.
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is offline
Old 11-02-2007, 11:12 AM   #5 (permalink)
FJ-Ollie's Avatar
Member Number: 6685
Exclamation Notice
I editted the first post. The thickness of the collars is 1.00" not 0.500".
Old 11-02-2007, 11:17 AM   #6 (permalink)
TIT-CRUISER's Avatar
Member Number: 9095
FJ-Ollie previously said: View Post
I am happy to see that you guys have come up with a bolt on fix.
It obviously took a bit of "brainstorming"
TITanium Metallic FJ Cruiser
TIT-CRUISER is offline
Old 11-02-2007, 12:06 PM   #7 (permalink)
MudLovingFJ's Avatar
Member Number: 8945
Send a message via AIM to MudLovingFJ
cant wait to test them out in a bit
The So-Cal Safari Snorkel Install Guy 7 chicken necks installed to date
MudLovingFJ is offline
Old 11-02-2007, 01:18 PM   #8 (permalink)
L8Apex's Avatar
Member Number: 2080
This looks like a great idea to keep the swaybar from shifting. Maybe I missed something in the swaybar link failure threads, but how does the swaybar shift cause the link to fail? Does it bring the links in contact with the shock/spring? *crawling under FJ to examine swaybar links*
Great job, FJ-Ollie! I'll be looking to buy these.
The Tank (aka "RED PILL") : 2007 FJ Cruiser, 4x4AT, black cherry
- Expedition One bullbar bumper
- Expedition One rock sliders
- BudBuilt skids (front, mid, TC, crossmember)
- Bilstein 5100 front struts, set at 1.75" lift
- GoodYear Wrangler Silent Armor tires 275/70/R17
The Fighter Jet: 2001 MR2 Spyder, silver
- 2ZZ motor/6spd swap
- TRD Sportivo suspension
- 3.0 Racing chassis bracing
- JDM Toyota hardtop, soft-top delete
L8Apex is offline
Old 11-02-2007, 01:23 PM   #9 (permalink)
frogeye's Avatar
Member Number: 6849
L8Apex previously said: View Post
Do a search for 'shifty' or 'bent' or 'broken' or 'links' .
Save The Cactus!!!
NObama!
Drill Baby Drill
frogeye is offline
Old 11-02-2007, 01:51 PM   #10 (permalink)
L8Apex's Avatar
Member Number: 2080
I found the answer, and posting here to help others:
The links hit the knuckle when the swaybar shifts.
L8Apex is offline
