Old 11-30-2007, 11:21 AM   #31
JCcruiser's Avatar
Member Number: 1947
Re: ARB Safari Snorkel to CAI Install w/Pics
Awesome work!!!! I also want to add a snorkle to my rig. I have the air raid cai. I wonder if the trd air box would fit the air raid cone filter??
JCcruiser is offline
Old 11-30-2007, 12:46 PM   #32
unknownuserx's Avatar
Member Number: 2376
Amazing job. Great looking FJ!
Black Diamond 2007 FJ Cruiser Prerunner
Intense Fabrication Prerunner bumper, Vision X lights, OME, BFG TA/KO 285/70/17, Demello Rock Rails & Clamps, FourTreks Shovel & Axe Mount, Magnaflow, TRD CAI, AFE TBS, Power Tank, M-PAC Springtail, and Defender Jerry Can Tire Mount.
http://www.myspace.com/cohibamike
unknownuserx is offline
Old 12-02-2007, 08:45 PM   #33
Member Number: 14599
Wow. Great information here. Thank you.
Sparman is offline
Old 03-01-2008, 07:03 PM   #34
Super Moderator
Shadow-Warrior's Avatar
Member Number: 3913
Ok Everyone sorry for the long delay on the Snorkel to CAI install. I wanted to try some other options first. That is why I had Dragon “Soft” Delete the thread. Today I went out with many parts in hand and tried to see if I could make something better work. It would have been a lot more fabing to do, but in the end it’s not going to work.
So, those with the CAI and want to install a Snorkel, this is about the best way I have found….I spent about $150.00 in other parts trying different applications to see if they would work any better, but no luck. It appears that my original way is still going to be the best. If you have any questions about or during your install, PM me and you can call me. Good luck to all you SCUBA drivers.
TLCA Member : #18084
Honorary AZFJ Club Member
Honorary SoCal Club Member
FJ Cruiser Club Member
Meet The RAPTOR 2007 TRD SE
Shadow-Warrior is offline
Old 03-05-2008, 07:15 PM   #35
FJoel's Avatar
Member Number: 4197
Thanks for the update Mike.
I am going to try another option here as well, but I am afraid I am going to run into the same conclusion you just made. This current setup (that I totally copied from ya!) may be the best way...
Ellis Precision:
Battery clamps are in stock and ready to ship!
FJoel is offline
Old 04-28-2008, 01:29 PM   #36
FJeddah's Avatar
Member Number: 19121
very nice Mike i wish i could do it myself
...Save Gaza...
'08 Black Diamond (5AT) 4X4
Birthday: April 19, 2008
Desert Knight - My Build-up
FJeddah is offline
Old 08-15-2008, 03:46 AM   #37
Funji's Avatar
Member Number: 21401
[center]********ARB SAFARI SNORKEL to CAI INSTALL MOD********
The I.D. is 5.25” x 3.38” I.D. awesome, so with part number in hand, I rush back down to my local hardware store, and ask if they would order one for me. They look in the book, and say, nope we can’t order that part, it’s not in our book. I say, ok, I’ll go order it online, thanks. I returned the other one.
ve!, perfect.
I then test fitted the reducer on the CAI box, again, Perfect!
Ok, at this point the only unknown was the dia of the existing opening through the fender curtain going to the outside fender. I removed my CAI box, messured the opening which is at 4" in Dia.
I then messured the outside of the reducer end, it also comes out to 4" Dia, Perfect fit!
I then installed the box with the reducer on it into the engine bay area, it fit like a glove. The only other item we will need will be a small 4" hard pipe, like PVC to make up a short transition piece from the reducer to the "ARB Air entry Hose" this will tie in everything perfect.
All the tools ready for the Surgery today
One last pic of the untouched passenger side fender.
Everything laid out ready to go.
I used masking tape to tape the fender up to reduce any damage to the paint. This will also help me see the marked holes from the template because of the Black vehicle color.
The template taped up and in position, ready for marking the hole locations.
I decided to go ahead and cut the large hole first and get it over with. One nice BIG hole in the fender.
I finished drilling out all the other holes as per instructions. After cutting the holes make sure to add some touchup paint around the exposed metal to keep it from rusting.
I then taped up the A-pillar for the holes that need to be drilled for the Snorkel attachment.
I installed the reducer fitting and a small piece of PVC to make up the transition to the Snorkel to the reducer.
You will need to remove your CAI completely from the engine. This will help installing the CAI box back in without trouble.
After alot of measuring, I found I needed to remove about a 1/2 inch from the CAI box inlet.
I also had to remove about another 1/2" from the reducer. This was removed from the CAI box side of the reducer. I also had to remove about 3" from the ARB rubber hose that comes off the Snorkel into the engine bay so that the mockup would fit. I would cut a little off, test fit, then cut some more off and test fit again until you have a good fit.
I found the best way to install is removing the reducer from the CAI box, then install the reducer FIRST on to the Snorkel, clamping it up. THEN install the CAI box to the reducer.
Reinstall the rest of the CAI to the engine, tighten everything up and your ready for some SCUBA Driving.
ARB Safari Snorkel Installed but still have to button up the inner fender liners.
that's hot,and beautiful
Funji is offline
Old 12-17-2008, 09:41 PM   #38
Member Number: 7344
First, Thank you for posting this CAI to Safari Snorkel install
After doing six (6) of these this past Sunday, a couple of changes.
  1. The PVC pipe should be 3" not 4"
  2. The Fernco will fit tighter with a #1056-43 you will still need to trim down the 4" end.
Fj always under constrution
Allpro coilovers,skids,rockrails,repowder coated bumper,bandi mount, Icon lower and upper links,Icon Track Bar,Cobra 75, 315/75/16 Kook's, Chamber ATX, Warn 8000,
TRD CAI Intake to Safari Snorkel
racefanmartin is offline
